tony.latham wrote:Well, mine is actually 29,418 pounds. If those were 3/8" Grade 2, your shear strength is 117,672 pounds.
* Like the OP's trailer, my TTT started out as a salvaged, small, derelict trailer. I couldn't give it away. So, I started building, but with visions of strength and durability over-riding common sense, and normal building practices. My wife was to use this trailer solo camping, I thought, so I wanted it to be a tank.
* No one wants their trailer to come apart on the highway, on bad roads, nor during a violent thunderstorm. It seems that some of us (myself, intentionally) may have gone overboard trying to secure our home-built cabin structures to the trailer frame, which had already been massively transformed. My original frame was small and broken, so the corrective build-up and over-build-up started on day one. After the initial <200 lb frame had received another 150 lbs of steel and larger wheels, then the floor became the next addition.
* Eight x 3/8" carriage bolts (in the cross-members), plus thirty-eight # 10 Tek screws (around the perimeter of the 4 8 frame)...all thru 11 gauge steel, probably has a pull-through value of 68924 lbs. Then, if I factor in the 48 feet of 3/8" beaded PL adhesive between the plywood and frame, the bond strength added is around 113184 lbs (at 524 psi when fully cured...subject to substrate failure of the Birch plywood-to-steel interface) = 181478 lbs of force needed to remove my decking. Certainly strong enough, even for my over-built "tank" of a trailer.
- carriage and teks.png (337.88 KiB) Viewed 1919 times
* With that much strength as a base to build on, I followed up in the same manner with 10 more tubes of adhesive, hundreds of 1/4" carriage bolts + fender washers + ny-locks, and dozens of steel corner and gusseted angle brackets to attach the 3/4" thick walls and roof to that floor (not to mention the additional interior framing added later. Similarly, I beefed up the already strengthened frame a year after it was first used, and put in an all-new HD axle and suspension parts.
* My trailer now weighs 11x its' original weight (and has cost probably 11x what I paid for it 30+ years ago =$50), when travel-ready. It seems that it is never to be completed, as I modify it after every trip. That's probably the part of this experience that I like the most. Even if the starting point is not what you'd like, it's the struggle to overcome the imperfections that is what I value most highly.
- trailer progress in stages.jpg (250.66 KiB) Viewed 1919 times
