I made 4 of these 90 degree brackets out of 2x4's to help hold the wall up. I am building this all by myself by the way. No one is helping me lift the pieces into place as the wet glue drips on my feet so I need to plan things out a bit differently.
Walls Up, bonded, braced, screwed, glue wiped off foot.
Then I installed the internal framing for the rear bed and front seats I made earlier. There will be a cabinet opposite the main door. The cooler will live on the bottom, a drawer next, then a couple shelves above that. I'm not sure if I'll build a door for it or not, but it has a curved front as you'll see later, so that would make it a bit trickier.
I plan on making the front bed turn into a small seat/table setup by using the center leaf of the bed as the table. I haven't sorted all the details of how that is going to work yet, but I'm sure we can figure something out..
I left off some interior skin panels at the bottom so I could access the screws to attach the wall. Once it was cured, I could then attach those missing skin panels.
Next, I started working on the drawer for the cabinet. I want it to sit flush when it closes, so there's no lip to hide my misalignment. It has to be perfect!!
I needed some smaller pieces of 3/4 Ply, but all I had was the piece I needed for the front bench, so I decided to cut that out so I could use the scrap from it. Here is showing the nice curve. The sticks on top are me trying to figure out exactly where I wanted to cut the table.
Lastly I cut out the hole for the side access storage. I still have to open it up a bit, but this is mostly there. I think I'm making my own door here too as I have been unable to find anything I like in an appropriate size. Not too big a deal I guess..
Well, that's it! You're all caught up to where I'm at today. It's been a slow process, but I'm not really in a rush. I'm in it for the ride and it'll be done when I'm finished. I just keep working on it and each step I see completed motivates me even more to finish it.
Please, ask questions, offer advice, make criticisms. Let me know what you think, or what I'm forgetting..
