Here is a great how-to for installing a Propex heater
rjgimp wrote:
...The 12 year old me was shocked to learn that I could use TWO or even THREE sleeping bags, one lighter one inside a heavier one, and would stay toasty warm all night. Who knew?![]()
Socal Tom wrote: BUT, remember that heat goes up and you can catch the roof on fire if you don't may attention.
Sparksalot wrote:Socal Tom wrote: BUT, remember that heat goes up and you can catch the roof on fire if you don't may attention.
Yes it does. I tried one of the little heaters that mounts to a 1lb propane bottle. In an amazingly quick time I had a scorch mark appear on Rose's wooden ceiling. I had set it on a shelf at about the halfway point in interior height. If I use it again, it'll be mounted much lower in the cabin to give the height above, and then i'll only use it a short time.
bobhenry wrote:You can always put in a wood stove !
lfhoward wrote:Sparksalot wrote:Socal Tom wrote: BUT, remember that heat goes up and you can catch the roof on fire if you don't may attention.
Wow! That’s awful! How many inches do you estimate were between the top of the heater unit and the ceiling?
Users browsing this forum: Google [Bot] and 6 guests
