The material is the same stuff used in countless gas station bathrooms across the country. It is the bumpy, shiny white stuff. Instead of having the finished (bumpy) side facing out, I installed it with the smooth back side facing out. A word of caution; When I installed mine, I liked the soft white color of the smooth back side of the panel when it was on my trailer so I just left it as is without any paint. Over a few years the ultra violet waves caused fibers in the surface of the paneling to fray and lift. I was planning to replace the paneling again with the same product but this time I was going to make sure that FRP was painted to protect it from UV light. As a temporary stopgap so that I could use it for one final season I painted the old surface with a couple of coats of Rustoleum white oil based enamel in the roll & tip method. That paint is still going strong a year later so I plan to wait another year before replacing the paneling.
When I originally installed the paneling to the 3/4 plywood body, I used contact cement to glue the paneling in place. I was never satisfied with the result. It hasn't give me any trouble but I can see wavering in the surface that indicates the panel has lifted there. I am not worried about it coming off because it is trimmed in with extruded aluminum all around the edges doors and and window When I do it again, I will use a slow set epoxy resin after quickly running my orbiter sander with a course disc over the tops of the bumps on the shiny side to make sure I get a good bond. So here is a pic of my 20 year old trailer. It was taken at or near Capital Reefs National Park, Utah while on a trip to Northern New Mexico.
