I have thought about something like this connected to a fireplace outside the trailer. Haven't tried it yet but you should be able to move heat from your outdoor fire to inside the trailer. The only downside would be going outside to add a log to the fire in the middle of the night.slowcowboy wrote:So back to the truck with heater hoses hooked by tractor hydraulic hose quick couplers to da teardrop....new thoughts...add car heater core in camper add 12 volt fan....or skip lines to truck and find new heat source to heat and re circulate the anti- freeze...one thoughts is a tank radiator heater 120 volts and heat pump for tractors...or some sorta portable heat source..just new thoughts on a old idea that never got built..slow.
