and I was planning on simply applying three coats of polyurethane varnish for UV protection...
tony.latham wrote:and I was planning on simply applying three coats of polyurethane varnish for UV protection...
Make sure that is a UV varnish of course...
I'm wondering if the black coloring in the epoxy will inhibit it?
Seem to remember you and some others don't like it, Tony, but wasn't sure of your reasons?
tony.latham wrote:Seem to remember you and some others don't like it, Tony, but wasn't sure of your reasons?
For me, it takes forever to dry. But maybe that's just what real varnish does.
I'm glad you brought this up because I need to treat my fiberglassed wall ends in the galley for UV and had forgotten about it.
swoody126 wrote:pox does knot like UV
¿ have you considered black exterior Rustoleum ?
reasonable price
common in big box stores
sw
noseoil wrote:If you store the trailer under a cover (garage, carport, etc.) it will not age too quickly with epoxy & a UV varnish. If it's stored in full sunlight, it's going to age fairly fast no matter what you do. The black Rustoleum would be as good as anything for durability, but the UV is pretty "hot" at 5,000' & very little cloudy weather in ABQ. That's why the Tortoise was under a cover in the back yard in Tucson, just too hot & bright in the summer. Glad to be in Raton now & parked inside a garage.
