Simple awning ideas?
Postby tinman52 » Wed Mar 04, 2020 9:31 am
Hi all
Been thinking about how to attach a simple awning to my TD.....needs to be detachable/easily stowable. I don't want it permanently attached, but some anchor brackets for it on the TD would be okay. Size maybe 6x8 or so? just big enough to sit under or keep the sun out of the camper if I have the door open...
I have one of those pop up 10x10 shelters, but since I travel alone they are tough to set up, plus they are bulky. Looking for some ideas for something simpler.
So what do you all use for an awning? Please post pics or ideas... Thanks!
BTW, my TD is 4.5ishW x 8'L
tinman52
Re: Simple awning ideas?
Postby Pmullen503 » Wed Mar 04, 2020 11:53 am
Sorry no photos but I use an 8x8 is plastic tarp tied to my roof rack. At the far end I found some shock corded replacement tent poles so I can have it high during the day but can also set it up lower at night to direct rain and dew away from the ground by the door. I have to use cords and tent spikes to hold the outer poles so inconvenient to set up but it does roll up to a compact bundle I store in an old camp chair bag.
Pmullen503
Images: 67
Postby Modstock » Wed Mar 04, 2020 7:07 pm
I built one of these for $60 . Seriously.
Provides lot's of shade. I think I may shorten it to fit on the new trailer.
https://youtu.be/1nJW2aT4i2s
Sent from my H1611 using Tapatalk
Modstock
Postby edgeau » Thu Mar 05, 2020 5:46 am
I have one of those 4x4 awnings attached to either side of my 'drop. They are a bit of a pain to set up with just one person though. Maybe something like the retractable ones often on caravans scaled down?Image
edgeau
Postby GPW » Thu Mar 05, 2020 6:38 am
Simple , one pole , regular tarp , nothing special to buy , works great … :thumbsup: 80798
Postby booyah » Thu Mar 05, 2020 8:07 am
Kelty makes a sunshade, with three legs, maybe pop one leg up on the camper, add a hook point to hook into inplace of a stake
https://www.amazon.com/Kelty-Sunshade-U ... 01JBX5HEA/
they also do a "big shady"
https://www.amazon.com/Kelty-Big-Shady- ... B07MWRBCBF
but it looks like its larger than the camper :-)
I've always liked the idea of an awning on my TD, but the roofline is too low to really support much of one for an independent one (like a normal camper). On the back I just use my 10x10 eazy up an call it good.
My build, 5x8 modified benroy "Smiles to go". Started April 2nd 2015, first trip August 2nd 2015.
viewtopic.php?f=50&t=63145
booyah
Postby drhill » Thu Mar 05, 2020 2:35 pm
Here is a picture of a canopy I use at the side of my trailer. So simple that I was able to sew it. It uses two fiberglass sectional tent poles crossed under the canopy and aluminum poles to hold it up. It uses an awning rail mounted to the side of the teardrop. Since mine is a woody, I used a wood awing rail.
147699
I do like the one pole, regular tarp idea too.
drhill
Images: 37
Postby tinman52 » Thu Mar 05, 2020 8:44 pm
Wow, THANK YOU all for the great ideas! :thumbsup: I knew this was the place to ask! I will likely end up using a combination of these to make an awning that works for me. I will post the end result here,
If anyone else has input, feel free to add it!
tinman52
Postby Graniterich » Thu Mar 05, 2020 11:04 pm
So I have a dog, occasionally he must be on a tether, so no awning, or side tables can have legs to the ground. I epoxied a rv channel to the roof, bent to fit. Use heavy duty magnets to the trailer frame for a test. These show pvc frame, moved on to foldable steel channel from old ez up.
Works great
Sent from my Lenovo TB-8304F1 using Tapatalk
Graniterich
Postby GTS225 » Fri Mar 06, 2020 8:33 am
GPW wrote:Simple , one pole , regular tarp , nothing special to buy , works great … :thumbsup: 80798
Personally, I'm liking this one quite a bit. Simple, few parts, and easy to set up. I just might have to steal it for my build.
GPW.....are you using something like this?
Roger
GTS225
Postby GPW » Sat Mar 07, 2020 5:17 am
Been using that for many years , read about it in Popular Mechanics many many years ago … so Simple … ( Hypar ) https://en.wikipedia.org/wiki/Hyperboloid_structure
Postby twinight » Wed Mar 18, 2020 10:53 pm
I use this over the hatch, but it could work on the side as well.
https://www.ebay.com/itm/Portable-Car-Roof-Outdoor-Camping-Waterproof-Car-Tent-Canopy-Tail-Ledger-Awning/193149034590?hash=item2cf894605e:g:NqYAAOSwW1NdnaYl
No permanent mounting required and sets up like a tent.
twinight
Images: 68
