Just when you thought it was safe to go in the water...
Anything electric, AC or DC
Postby Tukanu » Wed Mar 04, 2020 11:46 am
I get it: When there is a red and a black, the red is hot. When there is a black and a white, the black is hot....except for AC where the white is hot.
Are you with me so far??
I'll admit that everything I know about electrical systems I learned by sticking my tongue in a light socket! Just when I thought I was getting a handle on this electrical thing, along comes a Chinese reading light with two red wires.
reading light.PNG (316.46 KiB) Viewed 3227 times
I'm going to take a wild guess here: When you have two red wires, the first one that goes to the switch is HOT......right??????
Building lil' Woody: viewtopic.php?f=50&t=71953
Tukanu
Re: Just when you thought it was safe to go in the water...
Postby tony.latham » Wed Mar 04, 2020 1:07 pm
If it were me, I’d guess with a multimeter.
Postby Tukanu » Wed Mar 04, 2020 1:12 pm
I have a meter, but what would be the process? Of course there were no instructions with the light!
Tukanu
Postby tony.latham » Wed Mar 04, 2020 1:18 pm
I’d test for continuity on those two wires with the switch in both positions.
If it’s a DC LED you might play with a nine volt battery and work it out that way.
What’s with the other pigtail?
Postby GuitarPhotog » Wed Mar 04, 2020 1:19 pm
If it's an LED, you won't hurt it by briefly connecting it backwards. Just try it, with the + to the switched lead first.
<Chas>
:beer:
GuitarPhotog
Images: 55
Postby Tukanu » Wed Mar 04, 2020 2:44 pm
The picture makes it look like there are three wires, but there are actually only two...both red!
I touched it to a 9volt and it lights up both ways + and -
Tukanu
Postby edgeau » Wed Mar 04, 2020 3:43 pm
Well it must be an old fashioned bulb not an LED. It does not matter which way the power flows in a bulb but an LED will only work one way. What is the other connector with the black shrink wrap on it?
edgeau
Postby Tukanu » Wed Mar 04, 2020 4:32 pm
It is supposedly a 12v LED reading light from Amazon. Inside the shrink wrap is a small circuit board.
Tukanu
Postby edgeau » Wed Mar 04, 2020 6:13 pm
That circuit board must be doing some smart stuff to give the LED the right polarity regardless of which way you hook it up.
edgeau
Postby Tukanu » Wed Mar 04, 2020 6:41 pm
Here are the spec's from Amazon:
Tukanu
Postby Tom&Shelly » Wed Mar 04, 2020 7:06 pm
edgeau wrote:That circuit board must be doing some smart stuff to give the LED the right polarity regardless of which way you hook it up.
A full wave rectifier so it will work with 12 vac? Even though it isn't spec'd that way? :thinking:
174145 170466 173366
Tom&Shelly
Palladium Donating Member
Images: 2282
Postby Tom&Shelly » Wed Mar 04, 2020 7:08 pm
Tukanu wrote:I get it: When there is a red and a black, the red is hot. When there is a black and a white, the black is hot....except for AC where the white is hot.
Not the subject of this folder, but for safety's sake--on 120 volt AC house circuits in North America, black is hot and white is neutral. ;)
Tom&Shelly
Images: 2282
Postby bdosborn » Wed Mar 04, 2020 8:03 pm
Interestingly, 12v hot for RVs is black and the ground is white. I've always thought that was a poor choice of colors but they didn't ask me when they picked it.
Images: 806
Postby GTS225 » Wed Mar 04, 2020 8:57 pm
For the record; In AC the white is not considered a "hot" wire. It is considered a "grounded conductor". The term refers to a method of "tying down" the AC voltage such that it doesn't exceed the 115 (nominal) to 125 VAC. Without the "grounded conductor", the AC voltage could fluctuate to something quite a bit higher, and damage your equipment. Do not confuse the term with ground wire. The ground wire is not normally a current carrying conductor, while the grounded conductor is a current carrying conductor. It's just that wire colors, set by the Nat'l Electrical Code, are white or natural grey for a current carrying grounded conductor, and green or bare copper for a ground wire. The rest of the colors can be used for your "hot" conductors, with the exception of yellow, that indicates that power is coming from a separate source into that particular enclosure.
Clear as mud, right? :? :D
Roger
GTS225
Postby H.A. » Thu Mar 05, 2020 2:48 pm
NEC calls for grounded conductors to be white. Does not matter if its AC or DC systems.
Said that. I think recently, abundantly marked exceptions are allowed. Probably due to abundance of DC solar.
Most RVs have a shorepower component. Thus, white grounded conductors. White is also standardised in most transportation equipment.
H.A.
Return to Electrical Secrets
