Intro and title, “motobox that my wife would camp in”
Re: Intro and title, “motobox that my wife would camp in”
Postby BigDave_185 » Fri Feb 28, 2020 12:20 am
Just because I don’t have enough projects
Picked up 2002 Honda XR200R. Going to fix it up for the 12 yr old.
Cleaned carb and air box tonight, ordered tires, cables, levers, tubes, motor oil. Going to add some pressure washer tomorrow and see if I can get it fired up this weekend
BigDave_185
Postby BigDave_185 » Sun Mar 08, 2020 1:41 am
Can anyone give me a issue with something like this?
12v water pump,
Six overhead LED lights,
The 12v cooler fridge (120 can size)
Renogy 400 Watt 12 Volt Monocrystalline Solar Starter Kit with Wanderer https://www.amazon.com/dp/B00BSZUHRC/re ... zEb3939GYR
BigDave_185
Postby featherliteCT1 » Sun Mar 08, 2020 4:47 pm
Respecting the solar system, in my opinion, the 4 panels alone are worth the $481.
featherliteCT1
Postby BigDave_185 » Sun Mar 08, 2020 7:25 pm
featherliteCT1 wrote:Respecting the solar system, in my opinion, the 4 panels alone are worth the $481.
do you think 400 is about right or am I over kill?
BigDave_185
Postby featherliteCT1 » Mon Mar 09, 2020 6:00 pm
Even though the number of solar panels actually needed is driven by the number of watts your devices will draw, if your wallet can handle it, and if you have room to mount four solar panels, I would think that four 100W panels would be an excellent start. I think you will appreciate the extra watts on cloudy days. I have three 100 watt panels and wish I had room for at least one more panel.
Check out Flboy, he has 800 watts
viewtopic.php?f=42&t=65498&hilit=flboy&start=2445
and about a 450 amp battery bank.
viewtopic.php?f=42&t=65498&p=1256434&hilit=flboy+batteries#p1256434
featherliteCT1
Postby flboy » Mon Mar 09, 2020 6:53 pm
Seems like a good deal with all the connectors and etc.. The first thing I'd upgrade would be the charge controller. You really want a MPPT controller instead of the PWM type. But that is an upgrade and this is a good price all other things considered. You need to consider what batteries to get. Two good Duracell 6VDC Golf Car batteries in Series would go great with this and give you good performance and keep up with the fridge and the few lights with no problem if you get a decent amount of sunlight each day. . More is better when it comes to panels and batteries.... but again... only if you actually need them. After you get use to the system, consider a MPPT controller. You can get an 30A Epever for about $129 whenever you are ready and then you keep the PWM controller as a backup in case the main controller fails. I have a 40A PWM controller in my drawer in the CTC in case I have a failure on the road. Will get me by until I can fix or replace the MPPT.
Don (Flboy)
https://youtu.be/6_-8cVdWUIA
https://youtu.be/MUcMM86LA2g
flboy
Images: 378
Postby BigDave_185 » Mon Mar 09, 2020 7:23 pm
Thank you both!! Now need to weather this stupid virus and the news. But momma is more understanding of the prep option when the city closes due to this. Easy to pack up and go to the Mt for a “ camp trip “ instead of sitting at home with this drama!
BigDave_185
Postby BigDave_185 » Sun Mar 15, 2020 6:32 pm
Ceiling insulation and the small loops for me to run the six E trailer lights I ordered last week.
Next up the alder panels
BigDave_185
Postby McDave » Mon Mar 16, 2020 9:56 am
Wow! Those walls are looking real nice. I did mine in a similar color (granite) and so far I really like it.
Nice job Dave.
McDave
McDave
Images: 412
Postby BigDave_185 » Sat Mar 21, 2020 7:54 pm
BigDave_185
Postby McDave » Sat Mar 21, 2020 8:30 pm
Beautiful! :thumbsup:
McDave
McDave
Images: 412
Postby BigDave_185 » Sat Mar 21, 2020 9:02 pm
Next up I’ll post my cabinet drawings on the floor plan
Need to look for water tanks and shower pan for a 3x3 room a toilet and sink, fridge maybe
BigDave_185
Postby Modstock » Sat Mar 21, 2020 9:17 pm
Looking great.
Sent from my H1611 using Tapatalk
Modstock
Postby flboy » Sun Mar 22, 2020 7:48 am
BigDave, really nice job on the ceiling. Way to go!
Sent from my SM-N970U using Tapatalk
Don (Flboy)
flboy
Images: 378
Postby BigDave_185 » Mon Mar 23, 2020 8:40 pm
I just made a over the phone purchase of a 2002 fifthwheel trailer. Wrecked, salvage what ever you wanna call it. $350 delivered and I hope the fridge works. The awning is intact and if I get lucky a 25ft flat bed trailer for the hard work.
Plan is to get it here and check to see if stuff I want functions. If so give those things and strip the rest of it to the frame and build a flat bed trailer for who knows what. Or sell it and make some money back on my project
BigDave_185
