What did you do today
Re: What did you do today
Postby GPW » Wed Apr 01, 2020 1:25 pm
Today , actually yesterday , I built a Space Ship. :o A possible design for a new Tiny Travel Trailer … ??? :R
Postby booyah » Thu Apr 02, 2020 7:40 am
I listened to some sage advice from a wise man
https://youtu.be/YUakLzaboMo
My build, 5x8 modified benroy "Smiles to go". Started April 2nd 2015, first trip August 2nd 2015.
viewtopic.php?f=50&t=63145
booyah
Postby Sparksalot » Thu Apr 02, 2020 5:23 pm
Installed a larger transmission oil cooler.
161498
Sparksalot
Images: 687
Postby pchast » Fri Apr 03, 2020 9:06 pm
Swept out and started cleaning up the garage work area some.
Washed clothes and dishes. Took some breaks.....
Watched the rain, sittin in a rocker on the porch for a while too. :D
pchast
Images: 97
Postby BigDave_185 » Fri Apr 03, 2020 10:36 pm
Trenched my whole yard for sprinkler/ irrigation water. Prep for sod
BigDave_185
Postby saywhatthat » Sat Apr 04, 2020 12:38 pm
Just drop off 200 DIY face mask to the near by homeless camp .Will trade toilet paper for Elastic.
Il suffit de le faire
viewtopic.php?f=50&t=73945
saywhatthat
Images: 135
Postby bdosborn » Sat Apr 04, 2020 5:41 pm
I finally got around to fixing the wheel well after the blowout last fall. I painted the sides with bedliner, screwed some galvanized sheet over the small hole in the front and replaced the mudflap.
Images: 806
Postby Modstock » Sat Apr 04, 2020 10:25 pm
saywhatthat wrote:Just drop off 200 DIY face mask to the near by homeless camp .Will trade toilet paper for Elastic.
Made masks for family today. Elastic is hard to find. Used 3 hair ties on each side.
Sent from my H1611 using Tapatalk
Modstock
Postby BigDave_185 » Sun Apr 05, 2020 10:08 am
Put almost 1000 ft of pipe in the ground. Started back filling some.
Finished off with a fire Image
BigDave_185
Postby dmb90260 » Sun Apr 05, 2020 12:02 pm
Here a couple YouTube links for making masks
https://www.youtube.com/watch?v=fySsaOojEVM&feature=youtu.be&fbclid=IwAR3KnpXpnAb0_yF_gfkXiKdzTp57Goocj4KcTFzbtqCYWRi2AmViLgdP0SE
https://www.youtube.com/watch?v=xL8ctct0Dz4
This has a lot of information on cloth etc and you can find a template to download for the basic pattern,
https://www.vox.com/the-goods/2020/4/1/21203241/coronavirus-diy-face-mask-homemade-tutorials?fbclid=IwAR2XZ6y77V4SgV2n9aaniWmZ5VetlghCIUi9EbIMkto8AUNABkXKbXBZHoM
If it does not load at first, hit reload.
A different one from NYT INCLUDES TEMPLATE for the main pieces which you can print as a PDF file
https://www.nytimes.com/2020/03/31/opinion/coronavirus-n95-mask.html
Fortunately, without tinypix I am finding it hard to upload pictures so you will not see my first attempt. :twisted:
Dennis
Join the Kenskill Karavan at:
http://autos.groups.yahoo.com/group/kenskill_karavan/
Real Men cook with Black Iron
The Buzz In the Dale: The Buzz In The Dale
dmb90260
Titanium Donating Member
Images: 134
Postby saywhatthat » Sun Apr 05, 2020 9:12 pm
https://www.youtube.com/watch?v=SdFpicvfjBY
This is what we are doing With a square of blue shop rags as filter they can wash
saywhatthat
Images: 135
Postby pchast » Sun Apr 05, 2020 9:16 pm
Went for a Bike ride. A 50 mile loop.
Stopped for milk on the way home. :thumbsup:
pchast
Images: 97
Postby dmb90260 » Wed Apr 08, 2020 1:06 pm
saywhatthat wrote:https://www.youtube.com/watch?v=SdFpicvfjBY
Mine has two layers open on one side so I can insert the Blue Shop cloth as the major filter and replace it.
This site is very good http://www.fabricpatch.net/face-masks-for-covid-19-relief.htm
It is very thorough including fabric recommendations.
They use a strip of metal from an aluminum cooking pan to keep the nose area tight.
I may adapt mine with small pocket to replace the metal strip. It is not strong an may wear out from use.
Stay Home. Be Safe. :D
Dennis
dmb90260
Images: 134
Postby noseoil » Fri Apr 10, 2020 5:00 pm
Working on another batch of blades, just to pass the time. These were left over from heat treating done when I still lived in Tucson, working on finishing them a little at a time. This one is 1084 steel (yes, it rusts if not properly cared for) with olive-drab canvas micarta. Small knife, just 5 3/4" LOA, but a good slicer.
161582
137905
noseoil
Images: 670
Postby twisted lines » Sat Apr 11, 2020 4:56 pm
noseoil; What grinder are You using?
I had this piece 5' X 5' X 1/8" fit and standing inside the front for a long time, trying to find time and patience; I mean get her to help :lol:
The Three screw'z inside the front Radi were one too many today.
Three Screwz.jpg (80.61 KiB) Viewed 6057 times
Racking up; And Rapin foam
twisted lines
