6 X 10 (V-nose) build
Re: 6 X 10 (V-nose) build
Postby Modstock » Fri Apr 17, 2020 7:37 pm
Thanks for the tip.
When I went out the next morning, I was surprised the wood soaked it all up.
So I poured another coat. Used a heavy duty heat gun. Wasn't as many bubbles. Seemed to work well .
It's dry now. Not glass smooth but has some shine to it.
Planning the next step . Getting the sink to work.
I have a question or two .
# 1.) Can a hand pump sink be rebuilt , new o-rings ect ?
I have a hand pump spout. Not sure it works.
# 2.) If I have to replace it. What is better
A foot or hand pump.
I've heard hand pumps can leak.
I may hit up state trailer tomorrow .ImageImage
Sent from my H1611 using Tapatalk
Modstock
Postby Modstock » Sun Apr 19, 2020 7:50 pm
Finished the countertops and installed the sink.
This sink I picked up years ago from someone parting a trailer out.
I really liked the Moab red look.
Framed in the V-nose/headboard with 3/4x1.5" .
Used 1/8" Luann to cover the rest.
Made the top panel removable .
Started on the porta potty enclosure.
Modstock
Postby flboy » Sun Apr 19, 2020 8:08 pm
It's looking good! Making great progress!
Don (Flboy)
https://youtu.be/6_-8cVdWUIA
https://youtu.be/MUcMM86LA2g
flboy
Images: 378
Postby Modstock » Mon Apr 20, 2020 11:08 pm
Thanks.
Nice warm day, I couldn't wait to get off work .
Picked up some trim. Cut and painted it white. Finished the V-nose with carpet under the trim and under the bed.
The list is getting smaller.
Modstock
Postby Modstock » Tue Apr 21, 2020 7:40 pm
Made the V-nose compartment reversible.
For when ya cant decide on the color.
Modstock
Postby Modstock » Thu Apr 23, 2020 9:10 pm
Found this lightweight medicine cabinet at Lowe's for $14 . It was in a unmarked box.
Finally get to mount the paper towel roller.
I've had this for years. Was for the teardrop but never fit right, so it never got mounted.
Till now.
Lil bungee cord keeps it rolled tight.
Modstock
Postby Modstock » Sun Apr 26, 2020 10:00 pm
Trailer is DONE !
Pic #1.)
Finished up the toilet compartment.
Also drilled some holes for future plumbing and cut out a notch for the foot pump .
Masked and finished painting the doors.
Went to work and sewed up the foam mattress cover.
The last memory foam mattress I had weighed a lot. So I decided to go a different route. I wanted something a bit more lightweight.
I ordered a sheet of 4" polyurethane foam with a medium density and some 2" closed cell pad. (Polyethylene)
(We cut it up for the power company and they use it for knee pads)
Black closed cell pad in hand.
Modstock
Postby Modstock » Sun Apr 26, 2020 10:11 pm
Foam cover on.
Grabbed some levelors for the windows. Had Lowe's cut em down. They block alot of light.
New sheets on and grabbed our pillows.
They seem much smaller in here than the teardrop.
I couldn't leave well enough this afternoon so I started making the slide out drawer.
For the most part , it's done.
This winter I'll be adding shore power and other things as well.
Modstock
Postby BigDave_185 » Sun Apr 26, 2020 10:49 pm
Looks great, I would definitely require a bigger pillow lol
BigDave_185
Postby ris » Mon Apr 27, 2020 3:59 am
That looks nice. Hope you get to go out soon and enjoy.
Richard
ris
Images: 126
Postby Modstock » Mon Apr 27, 2020 9:38 pm
Thanks guys.
Cant wait to go camping.
Today I finished up the sliding drawer and the bedding arrived. We must have looked at a hundred different comforters .
Wanted something to break up all the grey and add some pop. Mostly I let her pick it.
It's all ready to move into.
.ImageImageImage
Modstock
Postby McDave » Thu Apr 30, 2020 11:36 pm
Nice job Modstock! That went pretty darn quickly. Looks great in there. Hope you get a chance to enjoy it soon. That comforter really does pop in there. I bet you'll wake up in a good mood everyday.
McDave
McDave
Images: 412
Postby Modstock » Sun May 03, 2020 8:08 pm
Took it on its first trip. Yep, already.
Making coffee inside is the best.
Modstock
Postby flboy » Sun May 03, 2020 8:10 pm
That's awesome! Glad you got out to use it! Everything perform as you wanted? Anything you'd change?
Don (Flboy)
flboy
Images: 378
Postby McDave » Sun May 03, 2020 10:51 pm
:applause: :thumbsup: :D
Very nice!
McDave
McDave
Images: 412
