foxontherun wrote:Good morning all,
I purchased a Magic Chef Mini Fridge this AM and in reading the manual, there are a few statements stating it is not DESIGNED to be used with an inverter or for RV use. My plans were to use it on battery when electricity is not available. I plan to use a dedicated pure sine inverter. Is there any safety reason that I shouldn't use it on inverter? Grant it, I am aware it would probably void the warranty. Any thoughts or considerations would be appreciated.
Thanks,
Harry
https://www.homedepot.com/p/Magic-Chef- ... /305026385
GuitarPhotog wrote:Nothing in the specs for that fridge give any idea of electrical power consumption, so it's impossible to tell if a 1000 W inverter will suffice. Inexpensive compressor fridges are notorious for high in-rush startup current requirements. An inverter that "sags" under heavy load may cause the compressor to stall and burn out.
YMMV
<Chas>
foxontherun wrote:Thanks for all the input and things to consider, I appreciate it. It's great to know that a pure sine will work out. My plan is to have a dedicated pure sine inverted just for the fridge and then a second one to do anything else.
As far as energy consumption is so far (using a P3 P4400 Kill A Watt Electricity Usage Monitor), the past 24 hours stats are .53 KW for 24.23 hours. Refrigerator temp after 3.5 hours was down to 46 degrees, so I adjusted the thermostat from 3.5 to 4 and checked again 5 hours later and fridge temp was 45. At the end of the 24 hour period the freezer temp was 7 degrees. The refrigerator was in a 86 degree garage.
I just put a mini tray of ice, regular tray of ice, and a 40 oz peanut jar filled with water to test ice making ability.
Thanks!
Harry
