by Air_N_Water2000 » Fri May 15, 2020 12:44 pm
Almost everything that I've been able to find shows mounting a wooden sub-frame to the top of the steel trailer frame and then mounting the floor to the wooden sub-frame. Is there a reason for this? My thoughts were to put frame cross-members under where there might be floor splices along with flat plate at the junctions between the side rails and cross-members. Then I could simply bolt 3/4" plywood directly to the frame thru the flat plate. I would bolt wood to the side of the frame to use to connect the side wall to. Any thoughts/comments/suggestions would be greatly appreciated.
- Attachments
- Floor Mounting.jpg (117.03 KiB) Viewed 1148 times
