Hurricane Hinge gasket question
Postby Tukanu » Thu May 28, 2020 7:06 pm
There is a 1/4" gap (by design) between the two sections of the hinge when the hatch is closed.
Should I be running a gasket thru this gap?
Building lil' Woody: viewtopic.php?f=50&t=71953
Tukanu
Re: Hurricane Hinge gasket question
Postby les45 » Thu May 28, 2020 7:41 pm
I did. Only a short section on the two ends to seal the outer edges of the hatch.
Before sealing the ends and installing edge trim.
Different view before sealing the ends.
Final view after sealing ends and installing edge trim.
les45
Images: 605
Postby Modstock » Fri May 29, 2020 5:26 pm
I did just the ends also .
Sent from my H1611 using Tapatalk
Modstock
Postby tony.latham » Sat May 30, 2020 6:42 pm
If you cut the vertical pieces off to clear the walls, you should end up with something similar to this:
:thinking:
Postby Tukanu » Sat May 30, 2020 7:48 pm
got it...thanks
Tukanu
