knova wrote:Would putting a door like this, at a 45 degree angle where my roof slopes in the front, be a bad idea from a water intrusion perspective?
I very well could be overthinking my need to access the electrical area in the future, at least on a frequent-enough basis that id need a dedicated access hatch.
tony.latham wrote:I very well could be overthinking my need to access the electrical area in the future, at least on a frequent-enough basis that id need a dedicated access hatch.
Isn't overthinking the norm for teardrop building?![]()
knova wrote:tony.latham wrote:I very well could be overthinking my need to access the electrical area in the future, at least on a frequent-enough basis that id need a dedicated access hatch.
Considering I’m in year 2 of my first TD build, i think I can get behind that line of thought. (To be fair my wife and I had our first kid in there too!)
tony.latham wrote:Under what circumstances would you need to access it?
My fuse box is accessible but I may never have to look for a blown fuse.
Tom&Shelly wrote:tony.latham wrote:Under what circumstances would you need to access it?
Hi Tony. In the PD 4045 fuses and 120 VAC circuit breakers are accessible from the front, but I don't think that's what Knova is talking about(?) Problem is that the 12 volt outputs from each fuse are an 8 inch wire hanging out the back of the unit, and getting them tied to something (and getting to them later, if necessary) is a bit of a challenge without some other way to get back there. I think that may be the problem Knova is considering(?)
One can crimp or soldier each wire to the wire going to the lights/fan/etc., but there would have to be a lot of slack once the PD4045 is re-installed, and that tends to get sloppy. And, of course, sloppy wiring may lead to other problems. (Did I write all that so it makes sense? I have a mental picture in my mind, but not sure I'm getting it down clearly.)
tony.latham wrote:You guys are reinforcing my 12 volt mantra: Twelve volts. Twelve volts. Twelve volts. Twelve volts. Twelve volts. Twelve volts. Twelve volts. Twelve volts. Twelve volts. (to infinity)![]()
T
I'll post a pic of the hatch wiring in my build thread.
knova wrote:In the meantime, I’m leaving plenty of slack on my cabling so I can pull the PD4045 out if necessary.
Users browsing this forum: Bing [Bot] and 6 guests
