rough -make do- work with a bit of a 'cover up' finish to make do - but with a nice finish?? not me... Well the other day when digging though some miscellaneous 'stored' STUFF = what I found, from left over from a 'prior' project = 2 - 'Mini Quick Fist' rubber clamps sized for 5/8in to 1 3/8in which are 'perfectly' sized for the 2 "As seen on TV" Atomic flashlights I already own. I mounted one on each side of the overhead headboard/shelf in my tear and YES!! They work GREAT!! - can now just reach inside from either side door and grab a flashlight - whenever needed at any time - can also just reach up - when inside and turn-on extra light when wanted ........ So as to give credit, when credit is due!! Thank You - Tony Latham - for giving me the idea that I will be -hence forth- crediting to you as being the one who I "stole" the idea from!!!!!!
