I used a simple lap joint (wall on floor w/cleat) to attach my walls. It is a ways down the road but I am starting to consider how I will trim that out. I'm thinking corner tape and butyl but want a wide trim around the bottom. Maybe 4-6 inches wide. Any thoughts or ideas for this trim? Here is a sample of where it will go.
This is along the front so you can see a support member, then the floor and finally the wall on top. Down the sides it's just the floor, wall and screws. The goal is to seal the layers, the screws and cover the frame. Final coatings will be applied before any trim goes on. Most likely a great primer and Line-X or similar.
Thanks in advance!
