saltydawg wrote:Okay first some specs. Over all trailer width will be 5'6 to 5'8", I want fenders on it so I want about 3 to 4 inches of tire/wheel past the wall. I want to use toyota rims which are 6 lug 5.5" and I think the rims have 4.5 from the inside of the rim offset. Tire size 31 10.5 r15.
I think I want a axle length hub to hub of 60 inches, and a frame outside width of 46 inches. Pretty sure that works out to about 2 to 2.5 inches of frame clearance from the tire. Due to tire height I am pretty sure a 0 degree angle on the arms which should give me 16 or ground clearance to frame.. I want the option for brakes, maybe now maybe later.
Okay I would love timbren axles but I would love to not spend that much. I dont want spring axles, so that leaves me flexiride or dexter torsion axle. It does not appear I can do the 6 x 5.5 lug pattern on the flexiride but can on the dexter. Well I might be able to order what ever hubs I want but I have spent the last 2 hours reading here, clicking may dead links for stuff and I am no closer to having an answer.
So the axle gurus please help me. What options do I have with the above info.
thanks
I want to use toyota rims...
As for the rest of your info while I appreciate it, it does me no good. My trailer will be 5'6 or 5'8 depending on how I do the walls to frame...
tony.latham wrote:
You should be able to interpolate your axles dimensions for any width frame from these two items I provided:
• Trailer width: 59.5” (60" cabin body)
• Hub face: 74”
Thus a 50" wide frame will take a 64" hub face axle. A 48" needs a 62"...
Mathematics.![]()
T
I called e trailer and they dont sell dexter torsion axles so they cant help.
See my posts above. I don’t think that’s enough.methridge wrote:Out of curiosity, how much room are you giving yourself, between the tire and the trailer frame/camper wall? I'm about to order a #9 Dexter torsion axle, and my frame width is 62", and I'm going with 72" hub face-to-face. That gives me 1.5" of space between the tire and the frame. I'm wondering if that's enough.
The only downside
assuming its physical dimensions work for you
is a little bit of added pulling weight
and a stiffer ride for the contents - maybe more bouncing - when loaded "too lightly".
