jamorgan3777 wrote:@tony.latham - Loved your build thread. I spent most of last night going through it. You answered a lot of my questions. You convinced me to try the "bedliner over fiberglass" route.
@saltydawg - That trailer is close to what I am trying to build. Wanted step sides around along with the fenders (as yours appears to have). Question, what is the angle iron on the outside for? Wouldnt the expanded or diamond plate go on top of the "shelf"?
Thanks for the quick reply.
jamorgan3777 wrote:I know there are pros/cons to each choice, but looking for the consensus on what to build my trailer out of.
2"x2" by 0.120 square tube?
2"x3" by 0.065 rectangle tube?
3"x3" by 0.065 C channel?
Beginner welder here. Thanks in advance for any/all insights.
JAM
twisted lines wrote:Someone on this form posted 1.5" X 2"
If I was starting another I would start with that but it would surely be .120 no matter which I chose.
With angle for axle supports.
GTS225 wrote:A little tip from me to all of you. I'll use Saltydog"s pic to illustrate, but when you build a frame, plug all open tubing ends. I can readily count ten, possibly twelve, open ends that paper wasps will attempt to build a nest in. I tend to do a 45* angle cut on the tube ends, and weld on a thin end cap, even if it's .060 sheet steel to keep the creepy crawlies from taking up residence in my frame.
Now, if you don't have wasps and hornets in your neck of the woods, more power too ya, but I'll bet you have other critters that you don't really want hitching a ride.
Roger
MickinOz wrote:jamorgan3777 wrote:... P.S. my welding improved out of sight when I bought an auto darkening helmet.
saltydawg wrote:And Mick you need to try mig welding, it is very easy.
