Socal Tom wrote:I've seen people dip a rag in rust preventative and push it through frame. You will probably get better coverage that way vs spraying it in from the sides.
saltydawg wrote:So my plan is to drill holes on the bottom of the frame where I need to and tap the holes 3/8-24 ( it works out to about 12 holes) and after spraying the coating putting in the screws then when I paint the outside of the frame just paint the screws over to seal them. This should allow me remove the screws if needed for inspection and or recoating. It might only be every few years to inspect but the frame will probably need paint that often anyway.
I plan on sealing the wire tube after the wires go in the frame, as well as using automotive seam sealer over my welds before I paint the outside of the frame. The idea of the seam sealer is if I have any pin holes or gaps in the welding and to fill where my welding is not the best to try to not give rust a place to start. Basically I am going for a water tight frame, that is protected on the inside.
Opinions or thoughts?
GPW wrote: Where we live , if you don’t treat it , it WILL rust !!! …
Ottsville wrote:I have a 20 year old utility trailer with 2x3 tube which have plugs cut out and welded in the ends. I have no idea what the inside of the tubes look like after 20 years, but I wouldn't even worry about it. Your frame will outlast what you are using it for most likely(unless you are dragging it through saltwater maybe). You could always build your trailer and have the whole thing galv-dipped.
I don't understand why so many people choose tube over channel.
BTW @Saltydawg, nice job on your trailer
Ottsville wrote:Saltydawg, I've gathered, maybe incorrectly, that you are in Virginia. I don't know if you know or not, there is a manufacturer of panels out in Fork Union and they do sell direct. (but they are limited on size)
https://www.carbon-core.com/
aggie79 wrote:Why not drill holes in the frame and spray in closed cell polyurethane foam such as Great Stuff? The closed cell foam should waterproof cracks and openings and the closed cell foam won't absorb water.
saltydawg wrote: Boat zincs need to be wet to work, preferably with salt water, that why they dont work that well in fresh water. They make Magnesium one for fresh water.
