I am trying to figure out what tail lights I want to get. I found one on amazon I like, really like. Its just way to big 13.4 by 6.1. Or am I being to sensitive about size, my camper will be on big tires, expo type looking I like the metal cage, I like the look. I dont what them so dam big and I dont want the reverse, which I can either dye it another color or just not hook up.
I'm a big believer in third brake lights --there's something to be said for eye-ball high waring lights. I use the four-wire units that are also turn indicators.
I'm a big believer in third brake lights --there's something to be said for eye-ball high warning lights. I use the four-wire units that are also turn indicators.
T
* I agree with Tony about visible rear lighting, though my version is not as attractive as his teardrop, but it still provides the desired effect.
* My trailer, though painted a semi-reflective silver on the hatch (and roof & front slope) wasn't as visible at night as I would've liked, so at first, I added more reflectors. Then, two more small, rear, (powered) running lights. Then, a trailer-wide rear conspicuity strip. Maybe I should've replaced the original lights with larger brighter ones, but the trailer already had some...and I was on a budget. And, my trailer is a series of ad hoc modifications anyway, so why not add-on as needed?
* Later, I made my own license plate frame, mounted midway up my hatch, for greater visibility (reflectivity), and used a large LED license light, with two additional LEDs, to boot. Finally, I added a "line of fire" LED light strip, with running-brake-sequential turn signals functions, as high up as I could, for better visibility I had always liked the old Thunderbird with sequential turn signals, and there are many cars with them, now, so, why not my trailer? They are very noticeable at night.
not-so-visible original lighting, supplemented with more noticeable add-ons.jpg (205.14 KiB) Viewed 2225 times
The Benroy design we chose has a large vertical flat area on the back, and we decided these triple lights worked well there. Since they have separate brake and turn signals, I had to put a converter (from e-trailer) in the hatch. These are nice bright LED lights, but they don't reflect real well, and they don't have built in side marker lights. Our plan is to install conspicuity tape along the black trailer frame. I also put the red side marker lights up high above the spare tire so they will be visible (and they do reflect, as does the 3rd brake light). They're probably about eye level for most drivers.
We decided to off-set the license plate so we won't scrape our knuckles against it when trying to find the hatch handle in the dark. (Illinois plate is just for sizing--haven't lived there in almost 30 years.)
This was a helpful thread and provided some good food for thought. My current plan is to use the light kit my trailer kit came with but in alternative mounting locations. I have thought about a third tail light for the extra visibility. The light kit is LED and pretty bright although it won't flush mount. Perhaps I'll shop around and investigate more.
I think I bought it at e-trailer, or Amazon, not this place, though. Tekonsha says (or at least used to say) it only works with incandescent lights, but it works with LEDs with no problems.
These are the pair I intend on using when I get to that point in my build, but that'll most likely be next year. Right now, my household is in full hospice mode.
Roger
Glass lenses, about 6.5" tall by 10" wide. 50's vintage firetruck lighting.
These are the brake lights on our teardrop, they were mounted on the frame & I had to open the brackets as they were forward about a foot with the added foot on the frame.
Back-up lights, 3rd brake light & license plate light are all on the hatch.
Build log: viewtopic.php?f=50&t=60248 The time you spend planning is more important than the time you spend building.........
