featherliteCT1 wrote:You are displaying some pretty impressive diagnostic skills. My interest is piqued!
featherliteCT1 wrote:I was looking at your battery and wires and was wondering if the wires were large enough to carry the start up amps without suffering a voltage drop. I went back and read your previous posts, and it appears that you have never had a “low voltage” error code.
I just wanted to be sure that you were not having a problems with voltage drop at startup. I would suspect that the unit draws up to 10 amps at startup. On the other hand, it appears that the wire length is fairly short which would mitigate the voltage drop. I would think you would need at least 12 AWG wire. Just trying to help brainstorm and eliminate all possibilities. I use 10 AWG wire for my diesel heater that draws 10 amps at startup.
pchast wrote:in my previous life I was a home boiler mechanic... Just a bunch of unrelated thoughts:
You may still have a short through the sensor mount after the insulator heats up. Check for microscopic cracks and carbon tracking under the mount connection.
Is there a transformer or coil that supplies a constant ignition? that could also heat up and short or open. if you have good pressure and flow, a constant flame would be less likely to be affected though.
Otherwise, you say the burner tube is dirty? There should be very little soot there if there is enough air flow for good combustion.
pchast wrote:Yes, the safety would be constantly checking the flame.
