pchast wrote:Okkkkkkkk.
Are there any jumpers on the circuit board or dip switches?
Still learning terminology... can you define what a jumper and dip switch are?
Can you see that the sensor is in the flame when it fires as
I expected?
No, once the heater is put back together, as it has to be for proper air flow, there is no way to see the position of the flame.
Or is it designed to be only heated by it?
It’s designed so that the sensor rod must be in the flame, but it’s not so much the heat that matters, but that the electrons can travel from the rod through the flame to ground on the gas jet.
Where is the circuit board in relation to the heat plenum?
It’s located in front of the air intake from the cabin (not combustion air, air to heat up)
Is it cooled by the air flow around it?
Yes.
A silly question: Is it designed to be installed "this side up"?
It can only be installed in one orientation.
Have you tested the wire/connector between the sensor and the circuit board for a good connection?
Yes and we can rule that out as a source of the problem. It works fine.
Last, you stated the sensors are new to you. I'd test one against the
other before bending it!
Yeah, I bought used. I should definitely test the sensor to make sure it’s not open. It looks fine.
featherliteCT1 wrote:We wait with fingers crossed!
