John61CT wrote:Nitpicky I know, but using fiberglass over foam is not "foamie", that term is specifically for canvas / glue / primer.
And any technique can be heavy or light,
the key to light weight is engineering with that as the priority, willingness to sacrifice strength
accepting the absolute lowest strength that is "just strong enough" and no more.
But in general using foam for structure rather than plywood, and leaving out the metal tends to be a lot lighter of course.
Getting **lots** of strength, at **minimum** weight, is where you start getting real advantages consulting professionals.
greygoos wrote:I must have missed that, can you show me how you came to that conclusion? I am very curious.I believe the first foam trailer on here was foam covered in fiberglass. I am not trying to be controversial just trying to get my facts straight. Thank
saywhatthat wrote:Why would anyone WASTE cash on epoxy over foam. Anyone tells you that Poly resin will eat the right foam HAS no clue. There pis off that they wasted there cash. ... with glass out side 1'' of THE RIGHT FOAM glass on the inside .
