Rolling wigwam /organic vardo/geodesic
Re: Rolling wigwam /organic vardo/geodesic
Postby John61CT » Sat Nov 07, 2020 9:06 am
Posted elsewhere, thanks G
GPW wrote:And while surfing You Tube , I saw this and thought of “ Thrifty Alternatives” … https://www.youtube.com/watch?v=sc6ZXR0 ... &index=126
John61CT
Postby GPW » Tue Nov 10, 2020 6:58 am
And a friend on facebook just gave me an idea for a Thrifty insulation under the canvas … Bubble wrap … :thinking: Plausible !!!
Postby Pmullen503 » Tue Nov 10, 2020 8:41 am
I've been looking into radiant barrier insulation (mylar faced bubble wrap) for a fabric covered, skin on frame style construction for a lifting roof build. The reflective insulation does a good job reflecting heat on a sunny day. It should make an unheated camper more comfortable on a cold night. It's not great if you are heating the air; it's R value is low.
There's a difference between reflecting radiant (IR) heat and resisting conduction of heat (R value).
Pmullen503
Images: 67
Postby John61CT » Tue Nov 10, 2020 6:25 pm
Reflectix, aka mylar faced bubble wrap is not an effective insulation **at all**.
R-value is how you measure true insulation effectiveness, this stuff is very close to ZERO.
With a large sealed airspace to the outside, mylar reflecting side pointing out
it can help prevent inbound **radiant** energy from entering the living space.
But those required conditions are not suitable for a mobile context.
Does nothing retaining heat pointing inside.
Any plastic does the "vapour barrier" function of sealing against convection.
The bubble wrap does nothing.
John61CT
