TinkerTailor wrote:Hello all -
New member here. I have read a fair amount on the foamie forums - thanks for your experimentation, expertise, and generous and inspirational posting!
I have an (unassembled) HF folding trailer in my garage (the 1200 lb. version), and I'm plotting a folding hybrid foamie a la casita folding caravan, etc.
I aim to follow these vintage plans
http://tnttt.com/VintagePlans/foldingtrailer.pdf
in terms of the mechanism by which the structure folds and opens, including the 45 degree chamfers in the wall joints to prevent water intrusion, though my dimensions and outline will be quite different (I have drawings but need to sort out how to post them - the outline, however, will be similar to this: https://homedesignlover.com/architectur ... me-office/).
My plan is for the camper's external dimensions to be 11' long by 6'4" wide by 7' high when open and a bit less than 4' high when folded for traveling. It will be mounted on the aforementioned harbor freight 4 X 8 trailer when in use, and will be removed from the trailer and placed on its side for storage (inside my small garage). The trailer will also be folded up for storage when not in use.
I am planning on using primarily 2" foam, though perhaps 1" on the front and back walls to cut down on the height of the folded wall/hinge assembly. I want thick foam, though, as I will be using it for winter camping at ski areas around Lake Tahoe, as well as for general family camping and surf trips.
I plan on using a relatively light wood framing around the edges for the panels (for strength since there is no monocoque and also for the hinges) and I am leaning towards pmf inside and out, though I am still considering skinning the exterior with 1/8 plywood as well. If I do skin the outside with ply I will use pmf for the interior. I plan to make a sandwich panel for the floor with nrp panels on the bottom, 2" foam in the middle, and 1/4" ply on top, possibly with vinyl flooring over that.
Fixed plexiglass windows rabbeted and glued into the foam on the front and back walls, and openable plexi windows on the sides, either in the wiley or sash style. Standard vent up top. All-in-one diesel heater, propane stove, & a smallish electrical set up with a solar panel is the plan (these would need to be easily removed before turning the folded camper on its side for storage, with the exception of the solar panel itself). Bucket toilet and possibly a marine foot pump sink like the one seen here:
https://www.youtube.com/watch?v=D2604Le2k0A.
I have been making surfboards out of XPS foam and skinning them with poplar bender ply and cork flooring for a number of years, so I have some experience with similar materials, and I'm finishing a small XPS and pmf boat to get some familiarity with that process as well. The pmf application on the interior of the boat has not gone altogether well, but thankfully there won't be any compound curves in the camper, and only the internal radius in the roof in front and back will be visible.
Any thoughts, suggestions, or critiques would be most appreciated. I'm hoping to build this over the summer. Thanks much -
TinkerTailor
TinkerTailor wrote:So, no new pics for the moment, but I have cut the window opening and framed it in with 1X material on the side wall with the door, and I've marked the window openings on the other side, though I haven't cut or framed that side yet.
TinkerTailor wrote:Insides of wall are covered in PMF. I've decided to go with PMF on the outside as well (instead of ply), since applying the PMF to these flat panels is going much more smoothly for me. Hopefully I'll get some pics up soon.
