featherliteCT1 wrote:
Do the LIFEPO4 batteries output a constant voltage so the buck converter would not be needed for the temperature controller?
yes they are very flat
Instead of a 12v heating element in the cooler, perhaps add a hot water bottle. Boil some water and put it in a gallon container with the water in the cooler . I would think it should provide enough heat. To keep things liquid for the night. I put a hot water bottle in my sleeping bag if it’s really cold.Cosmo wrote:I came to the right place! Great information. I like the cooler idea and it would work great for a weekend.
After a longer period even the contents will cool.
For what I am doing the suggestion to put some heaters in the cooler with such low power consumption might be the long term ticket.
Ages ago I had a similar looking heater for a waterbed.
Where did you get the thermostat? Sounds great.
With the water bed you had to have the entire heater in contact with the cool water or the heater would burn. Maybe a flexible water container will do that.
Appreciate the help. Sometime I think I spend more time planning for and testing stuff than I do camping.
=Cosmo
Cosmo wrote:"Instead of a 12v heating element in the cooler, perhaps add a hot water bottle. Boil some water and put it in a gallon container with the water in the cooler . I would think it should provide enough heat. To keep things liquid for the night. I put a hot water bottle in my sleeping bag if it’s really cold.
Tom"
I like this suggestion a lot. Its low tech and easy to replenish. Perfect.
Thank YOU
=Cosmo
