Graniterich wrote:I really am struggling to believe that humidity is causing blowing fuses.
tony.latham wrote:I've been scratching my head over this, wondering how a brushless motor could short from moisture.
But I think Mick has enlightened me with his comment about the electronic board.
You might consider replacing the fans with a different brand. I was looking on Youtube and they are all over the place with their board designs.
Socal Tom wrote:tony.latham wrote:I've been scratching my head over this, wondering how a brushless motor could short from moisture.
So in order of probability as determined by me![]()
1) The wiring was damaged during install, and moved enough on the trip to cause a short.
2) There is a combination of low battery voltage and small guage wiring leading to excessive amperage accross the fuse causing it to blow
3) something else is on the curcuit and you forgot about it
4)poor grounding, leading to something like #2 above
5) Faulty fan
6) poor connections somewhere in the curcuit leading to something like #2 above
7) Its the wife's fault, ( I don't know how, but its her fault)Its the dogs fault ( see above)
9) Bad switch ( see #2 above)
10) condensation causing a short
