Help on Base Construction Issue
Postby Kuda » Fri Feb 05, 2021 4:18 pm
Hey all. I am beginning my first build and upon constructing the base of the trailer I ran into an issue with the proportions of framing. The left side is shifted downward about 1/2". I believe this is due to my 5 x 8 trailer being off square by 1 or 2 degrees. The edges sit parallel and completely flush with the trailer so I am not as concerned with the walls as much as I am where the ceiling attaches to the base. Any tips on how to fix this problem? I included a few images to show what's giving me the trouble. Thanks!
Screen Shot 2021-02-05 at 5.13.37 PM.png (681.34 KiB) Viewed 1315 times
Screen Shot 2021-02-05 at 5.13.29 PM.png (647.52 KiB) Viewed 1315 times
Kuda
Re: Help on Base Construction Issue
Postby saltydawg » Fri Feb 05, 2021 4:47 pm
Either fix the frame or build the walls to match the curve in the frame. This would give you a "level" roof.
Scott
Lost in Maryland
saltydawg
Postby MickinOz » Fri Feb 05, 2021 4:59 pm
Here in Oz, we could take that trailer chassis to a crash repair shop and get it put on the Mayrack and pulled straight.
I even know DIY car restorers who have chain down points cast in the garage floor who can pull stuff straight.
Maybe you know someone like that?
Beats trying to build your teardrop off square to suit the frame.
MickinOz
Postby bobhenry » Sat Feb 06, 2021 6:11 am
Put the frame up on blocks and weight it heavily to flatten out the frame. Build your body true and correct and the shell will eliminate the droop in the frame if designed well enough.
Postby tony.latham » Sat Feb 06, 2021 9:48 am
Is that a bolt-together trailer? If so, it needs to be squared up. Just measure the diagonals.
:thinking:
