Newbie Questions
Re: Newbie Questions
Postby rjgimp » Sat Feb 06, 2021 12:34 am
Dahlia47 wrote:
tony.latham wrote:
It rotted.
OSB?
What is OSB?
Oriented Strand Board. Comes in 4'x8' sheets in a few thicknesses like plywood but is basically thin chips glued and pressed into a sheet.
-Rob
rjgimp
Images: 7
Postby MickinOz » Sat Feb 06, 2021 2:10 am
Dahlia47 wrote:
tony.latham wrote:
It rotted.
OSB?
What is OSB?
'Orrible Second-rate Building material :thumbdown:
MickinOz
Postby bobhenry » Sat Feb 06, 2021 6:03 am
Used to be but new binding resins have stabelized the product and are now rated from an engineering standpoint to be comperable. I have 3 campers with osb shells that have been stored out of doors their entire life one built in 2011 and most finished by 2013. All are doing just fine.
Postby Dahlia47 » Sat Feb 06, 2021 5:57 pm
That type of board wasn't used in the original build. We did use it for the roof. Sealed the roof tight. The flex seal was perfect. No leaks since I pout it on. The other panels and wood that I used have been of better quality. The better quality wood still got sealed. Better safe than sorry.
Dahlia47
