Slide-out and Lift Systems Secrets
Postby iconicflux » Mon Feb 15, 2021 11:05 am
Instead of tossing ideas into one place I thought I'd start a thread for slide-outs and lift systems to gather info on how the different manufacturer cable systems work.
The number of hours I've spent finding sensible info now is pretty high.
Lifts:
Coleman:
Andrew Gibbens lift design (modified for XPStream by OP827):
http://tnttt.com/viewtopic.php?p=38750#p38750
Slide-outs:
The 6 Types of RV Slideouts:
https://www.youtube.com/watch?v=nYDBvuWnHrs
Pulley/Cable Systems:
BAL Accu-slide: https://www.youtube.com/watch?v=V7F6HRn_4cQ
Worm Drive:
Lippert aka. Schwintek: (I dislike these guys. They will NOT sell aftermarket. You *can* order parts but I have yet to figure out what their rack & pinion pitch & depth is to have one made. I get that they try to not let you buy their stuff aftermarket because they had some brand damage from inappropriate use but holy cow we're just a bunch of home builders.)
Rack & Pinion:
LCI (Lippert):
Possibly: Gate Opener Hardware has easily available rack & pinion units.
Other:
LiftCo Glide-Out Rooms:
https://www.liftcoproducts.com/all-prod ... descending
DIY:
Possibly Gate Opener Rack & Pinion:
https://www.alekoproducts.com/ALEKO-AR9 ... nor-ap.htm
https://www.youtube.com/watch?v=kmKkNRVc6v8&t=18s
iconicflux
Re: Slide-out and Lift Systems Secrets
Postby Ottsville » Tue Feb 16, 2021 8:16 am
Nice work on getting that information together.
One source for slide out (and other RV) equipment is the salvage industry. Wrecked RV's are a dime a dozen and our local u-pull it yard usually has at least one there.
Ottsville
Postby aggie79 » Tue Feb 16, 2021 8:59 am
Ottsville wrote:Nice work on getting that information together.
Here's another source for new slide-out hardware: http://www.busrvparts.com/slide_out_units.htm#DYI_Slide_Out_Drives_and_Parts.
Postby iconicflux » Tue Feb 16, 2021 9:58 am
Their slide-out rooms are actually Liftco glide-out rooms which use a design that is uncommon. It appears they have the motor in the floor of their slide-out. The box that goes up above the floor from the motor is their gear box which then appears to turn a lead screw. The floor itself is on a track and you'll notice it has some glides near the top. for when the floor is extended or fully in.
I don't know anything about the reliability of this system at this time but I'd certainly love to know more about it.
iconicflux
