Capebuild wrote:I've noticed some trailer profiles, on the bottom, carry the sides straight down to the chassis frame, making the frame meet up with the corners of the trailer's profile. Others have a generous radius or curve on the profile's bottom
and where the chassis frame meets where the curve transitions to the bottom flat. See attached. One advantage I can see of having the curves is it allows the chassis frame to be less in overall length. I suppose it's also an aesthetic preference. I'm also wondering if it provides less support to the overhang of the trailer cabin in the galley area if the chassis frame does not extend out to support the galley in that area.
I'm also wondering if the chassis frame could be even less length in the rear so the trailer would overhang more than what is shown. How much overhang can there be? I'd imagine there could be a significant weight saving on the frame.
I'm asking for any thoughts others might have on this.
Thanks very much for any thoughts and insights.
John
Pmullen503 wrote:A thought about the "roll under" detail and water. You don't want to create a place where water could pool between the frame and the body. Details like a drip edge to direct any water away should be considered.
I do like the way it looks.
Capebuild wrote:Thanks all for the feedback.
Danny, what you've shown is a really great idea. Thanks for posting those photos. Before the photos in your album disappeared a while back I had grabbed a bunch of screen shots of your builds and was just looking at them and especially the bottom radius corner areas (really nice trailer BTW, as I've said before, very clean design). Just so I'm understanding how you did this (radius the corners with those add on pans you show).... I now see your cabin sides actually extend down past the bottom surface of the chassis frame, the tongue box sides extending even a bit more. I suppose you loose some road clearance. How much distance between road and bottom of trailer do you think there is? If I were to do a cross section through middle of your trailer, would it kind of look like half an I-Beam, where the sides extend down past the chassis, the chassis frame being the horizontal of the half I-Beam and the two side walls being the verticals of the half I-Beam? I guess what I'm asking is do you have a photo showing the bottom of your trailer?
Thanks, very much, again.
John
Edit: Danny, I've attached a rough layout to kind of show what I think your setup looks like to accommodate those curved pans.... having the right and left sides overhang below the chassis frame. Does this look correct? Thanks
2nd Edit: Danny, I'm assuming you have a 5 foot wide trailer...how wide and how long would you say your chassis frame is, the section where the cabin is fix to, the outer dimension of that rectangle (and I realize your cabin extends out
over the "Y" of the tongue area.... but just the rectangular area? Thanks so much if you have that info.
Users browsing this forum: Bing [Bot] and 5 guests
