Home-made super stubby screwdrivers
Postby Tom&Shelly » Fri Mar 05, 2021 6:04 pm
Found these in the discount bin of a hardware store a few years ago:
164491
Somebody obviously took the blades like the kind that comes in a box of deck screws, and stuck them in plastic. I was so thrilled, I bought a set for Shelly for our anniversary*.
I needed to borrow them back today, as I worked on our teardrop wiring and had to tighten screws on a terminal block someone had located in a tight place.
I also had to coat a hole I'd drilled in the floor (for a cable) with epoxy. Suddenly I thought of a great way to use the left-over in the batch
164492
This one will have a wider handle because that was the only plastic cup I could find that has a flat bottom. All the better for torquing the little suckers. If this works, it'll go in the tow vehicle's tool box. I will let you know...
* Aren't I the romantic devil! In fact, she builds doll house furniture and loved them.
174145 170466 173366
Tom&Shelly
Palladium Donating Member
Images: 2282
Re: Home-made super stubby screwdrivers
Postby GuitarPhotog » Fri Mar 05, 2021 11:49 pm
I have a pair of those, except in red plastic. A #2 Vessel point (a Japanese Phillips head rip-off) and a 3/16" straight blade. I bought them in Akihabara, Tokyo, Japan in ~1987. They actually come in handy once in a while (decade).
GuitarPhotog
Images: 55
Postby tony.latham » Sat Mar 06, 2021 9:54 am
I should fire up the 3D printer today.
https://www.thingiverse.com/thing:3079591
Postby Tom&Shelly » Sat Mar 06, 2021 10:15 am
GuitarPhotog wrote:I have a pair of those, except in red plastic. A #2 Vessel point (a Japanese Phillips head rip-off) and a 3/16" straight blade. I bought them in Akihabara, Tokyo, Japan in ~1987. They actually come in handy once in a while (decade).
Yep, but when you need one...
Tom&Shelly
Images: 2282
Postby Tom&Shelly » Sat Mar 06, 2021 10:22 am
tony.latham wrote:I should fire up the 3D printer today.
Neat!
With mine, I may try and finish it by drilling some holes in the epoxy around the bit, cutting a circle with a scroll saw, and then sanding smooth the edges. (Yours is less work but mine uses otherwise wasted epoxy.) :lol:
Or, I could just leave it as is, make a few hundred more, and scatter them around the campsite as a deterrent to bears (and anyone else wearing bear feet)! :wakka wakka:
Tom&Shelly
Images: 2282
Postby tony.latham » Sat Mar 06, 2021 11:32 am
I should make some bear-paw shoes for camp track making. They'd go along with the ever-present rubber snake.
Tony :thinking:
Postby tony.latham » Sat Mar 06, 2021 8:59 pm
3D printers are handy. :thumbsup:
Postby Tom&Shelly » Sat Mar 06, 2021 10:31 pm
tony.latham wrote:3D printers are handy. :thumbsup:
Looks great! :thumbsup:
Shelly's been looking at 3D printers now and again (mainly for her miniatures, aka, doll house furniture). I suspect at some point, when we have a little free time and a little money simultaneously...
Tom&Shelly
Images: 2282
Postby Greg M » Sat Mar 06, 2021 11:00 pm
Any excuse, eh, Tony?
Greg M
*Geek Extraordinaire
Images: 85
Postby tony.latham » Sun Mar 07, 2021 8:22 am
Greg M wrote:Any excuse, eh, Tony?
I scroll through the Thingiverse site from time to time just to see what I might want to print up. Two days ago it was a handful of scalpel handles.
