window in Barn Door
window in Barn Door
Postby slgrafton » Sun Mar 07, 2021 6:57 am
finally warmed up and dried out enough to get the window in the Barn Door. Turned out pretty well.Not so much of a tomb when you are sleeping
thumbnail_63675208358__7BA9254D-ED75-4CED-AC51-DCF26F48C451 rear window.jpg (71.07 KiB) Viewed 1621 times
slgrafton
Re: window in Barn Door
Postby onehoser » Sun Mar 07, 2021 12:19 pm
nice work. i’m waiting for warmer weather to instal 2 similar windows in my side door and 1 rear door in my 6x12
I am the wisest man alive, for i know one thing, and that is that i know nothing. (socrates)
onehoser
Postby Rainier70 » Sat Mar 13, 2021 3:56 pm
Nice job. Did you access the inside of the door to add bracing or just slide some in from the hole?
Rainier70
Images: 244
Postby onehoser » Sat Mar 13, 2021 8:05 pm
Rainier70 wrote:Nice job. Did you access the inside of the door to add bracing or just slide some in from the hole?
it’s easy on my 6x12 doors, they’re solid osb, no interior framing.
onehoser
Postby Modstock » Tue Mar 16, 2021 12:26 pm
What is on your upper left door ?
Is that a removable vent or other.
Sent from my SM-A115AP using Tapatalk
Modstock
Postby slgrafton » Fri Mar 19, 2021 4:00 am
Rainier70, The door was solid plywood. Made it alot easier
slgrafton
Postby slgrafton » Fri Mar 19, 2021 4:10 am
Modstock wrote:What is on your upper left door ?
They are vents for my dual hose AC. I didnt want to cut holes in the floor.
slgrafton
Postby Modstock » Fri Mar 19, 2021 11:04 am
Where did you get em?
Modstock
Postby slgrafton » Fri Mar 19, 2021 5:06 pm
slgrafton
Postby Modstock » Fri Mar 19, 2021 8:02 pm
Thanks. I may use something like that in the future.
Modstock
