Thx Sharon for the link.
Luv looking at other builds for ideas and creativity.
Hammering away at the build. Gettin on it and gettin r dun!
To date have 80 hrs into it and now being at the stage of PMF walls, roof and paneled interior walls with trim.
And ready to finish the interior, going over layout design and placement. Further final paint coats on PMF for final color.
FYI, took me 5 gals of paint for three coats to PMF canvas to ply siding. Approx 200ft2. First coat on surface, coat on canvas, paste together and a third coat over the top to totally seal them together and dry as one piece making sure to do it all as quickly as possible. After this stage, paint goes on smooth and absorbed less as the canvas is already saturated. Will require a few more coats to ensure it's waterproof. Imho, 2 more coats sufficient probably 2 gallons. With mistint paint so cheap, usually buy a 5 gallon bucket at $30 and use all of that up.
Walls insulated and covered inside and out. 1.5 inch Rtech in walls with 2 inch in ceilings giving overall SIPS strength properties. Doubled the luaun on the roof with glue and screw.
With my T truss design, the roof is surprisingly strong with. 2 layers of ply, 1x3 plus 1x2 T, and single inner layer of luaun all glued and screwed. How strong you may ask?
Well I like to stand by my build.
Or more accurately, stand on my build.
A roof truss stress test.
I'm still here.
- tmp-cam-7070873366576282164.jpg (89.15 KiB) Viewed 1756 times
On the road to Shambala...
