Flboy - Custom 6x12 Off-Road Toy Hauler Conversion
Re: Flboy - Custom 6x12 Off-Road Toy Hauler Conversion
Postby flboy » Sun Mar 14, 2021 8:03 pm
Gonefishin: Thanks... I will definitely ask you about the good places when I get out there. It is just a matter of when... life events have thrown a curve ball to my wife an I this year and we are dealing with it.. I am not as free to take off on extended trips as I had wanted to be. At least for now.
Hi Bruce... the panels are made and sold by Newpowa
Don (Flboy)
https://youtu.be/6_-8cVdWUIA
https://youtu.be/MUcMM86LA2g
flboy
Images: 378
Postby flboy » Mon Mar 15, 2021 11:11 am
Picked up the Sink and AC today. Not sure if I will undermount or overmount, but I have options. It is a 15x15in Bar Sink that is 7 inches deep. I like it.
The AC is a 5,000 BTU GE. Starts up fine from Eco mode on my Honda and draws less than 400W on highest settings. I think this is going to work well especially with the 420W of Solar panels if I run AC on the 1500W PureSine Inverter in full sun from the 280Ah LifePO4 bank that charges at full current all the way.
Threw in a pic of Lexus (puppy update).. Lexus (Lex) is 11 months old now.. She has turned out to be a good traveling companion, camp watch dog, and is very alert and protective of me when on leash. Also, she has long hair which I did not know when I got her @ 6 weeks old, but Lex is a beautiful dog in my opinion; nonetheless. A little more work to keep brushed out for sure!
Hope to be picking up the trailer in the next few weeks. I am getting anxious to start this build.
Sent from my SM-N970U using Tapatalk
Don (Flboy)
flboy
Images: 378
Postby featherliteCT1 » Mon Mar 15, 2021 4:31 pm
What brand and model of inverter are you going to use ... I did not spot it on your parts list. Thanks
featherliteCT1
Postby flboy » Mon Mar 15, 2021 8:48 pm
featherliteCT1 wrote:What brand and model of inverter are you going to use ... I did not spot it on your parts list. Thanks
It is a WZRELB 1500W Pure Sine Inverter. I already had it from my previous CTC when I upgraded it to a 3000W Inverter. These are relatively cheap, but I have found them to be very reliable and well built. They do cause some HAM Radio noise so there is some EMI coming from them... but I just turn it off if I am going to use the HF Radio. This will run anything I will need in the 6x12 build.
Don (Flboy)
flboy
Images: 378
Postby featherliteCT1 » Mon Mar 15, 2021 8:50 pm
With much thanks!
featherliteCT1
Postby S. Heisley » Tue Mar 16, 2021 5:34 pm
You're gonna have to get a side car for Lexus, your fur girl!
Postby Karebru » Tue Mar 16, 2021 6:45 pm
Lex is lookin' good!
Hey Don, are you happy with your Sherline tongue weight scale?
I'm getting ready to order one.
Did you get the 1,000 lb version?
Thanks!
I'm not going outside until the temperature is above my age.
Karebru
Postby flboy » Tue Mar 16, 2021 7:25 pm
Thanks all on Lex.
I like the scale. I think it is a nice tool for the box and takes all guesswork out.
I bought the 0-2,000 lb model.
Don (Flboy)
flboy
Images: 378
Postby Karebru » Wed Mar 17, 2021 10:19 am
Thanks 8)
Karebru
Postby Philip » Thu Mar 18, 2021 9:43 am
Better add a small vaciuum cleaner into the build. If your going to be hauling the puppy around you will need it.
We have a golden ret. That thing is a fur factory. We have to vac the van every day when she is with us. But she likes to travel. :lol:
Philip
Images: 323
Postby flboy » Thu Mar 18, 2021 9:59 am
Lol... yes... already have one that uses the same battery as my 20V Lithium drill.
Don (Flboy)
flboy
Images: 378
Postby hankaye » Fri Mar 19, 2021 6:43 am
Flboy, Howdy;
Depending on Lexi's attitude towards the high pitch noise from the vac. you could vacuum her
to help with the fur problem. Good for a lot of the surface hair or as a finish to a good brushin'.
hank
hankaye
Postby flboy » Mon Mar 22, 2021 8:06 am
Received the fridge today. It is a 2.5 cubic ft Black and Decker. It uses less than 60 watts while running. I am going to let it run a few days to make sure it is good.
I have had good luck with these type fridges in the CTC when using a pure sinewave inverter. They seem to work well and do not use more power than the more expensive DC versions, except the caveat that the inverter needs to be on all the time... which I typically have on anyhow since they draw just a few watts in standby and the battery bank will be way more than needed to run the fridge for a few days with no sun.
Note that a modified sinewave inverter will prematurely kill the compressor motor.
Don (Flboy)
flboy
Images: 378
Postby ISOTNT » Mon Mar 22, 2021 11:54 am
Are those fridge shelves tempered glass or acrylic? I was thinking of returning the 4.2cu ft MAgic Chef one I got as the shelves are glass and I am afraid to really use them while traveling. I was thinking of replacing them or maybe just returning it for one without the glass. Also, if you don't mind me asking, what are you intending to use to keep the fridge door closed in transit? Thanks!!
ISOTNT
Images: 6
Postby bdosborn » Mon Mar 22, 2021 12:15 pm
Can you meter the kwh usage for a 24 hour period with the kill-a-watt? That will tell you a lot more about the energy usage than just the watt draw.
Images: 806
