eLink wrote:Yes, similar to VW seals. Here is my best guess using a TrimLok product. I was mostly concerned about its application on thin plywood. But based on the examples I have seen, it should work ok.
tony.latham wrote:I just want to try and confirm the distance is correct (regarding the 40/60 rule).
It looks fine. It should be close to the 60/40 on the trailer frame, not the total length of the trailer. Just make sure you plave the axle using actual stubs, not the torsion axle's cross-member.
I think I'll need to provide a bit of flat for the fan to rest on.
Capebuild wrote:My concern with that technique of mounting a sheet of plastic like that is the spring back (memory) from the plastic. I just don't know if that will put enough force on the rubber gasket to kind of want to pull it out, or otherwise stress it. I suppose the thickness of the plastic plays a part. I would love to find a vendor who can heat bend Lexan. That would work well, I think. If you're using .125 plexi, maybe it's not an issue, bending it like that.....but
.250 material, just not sure. I saw another build that used .125 Lexan but didn't use a rubber seal.... they seemed to have held the Lexan in place with aluminum trim, screwed the trim down, trapping the Lexan..... and I imagine using a urethane sealant of some sort.
bobhenry wrote:I used Lexan for my sky light
