Flboy - Custom 6x12 Off-Road Toy Hauler Conversion
Re: Flboy - Custom 6x12 Off-Road Toy Hauler Conversion
Postby piperpilot3tk » Mon Mar 29, 2021 8:56 am
You need one of these tables for the portaband. https://www.swagoffroad.com/SWAG-Portab ... _c_35.html
I have used my HF portaband with SWAG table to fab lots of stuff.
piperpilot3tk
Images: 29
Postby BigDave_185 » Mon Mar 29, 2021 1:09 pm
That right there is a good idea!!
I picked up my older saw and set about rebuilding it. Until I opened it realized everything was in perfect order just needed some paint
BigDave_185
Postby flboy » Mon Mar 29, 2021 1:24 pm
piperpilot3tk wrote:You need one of these tables for the portaband. https://www.swagoffroad.com/SWAG-Portab ... _c_35.html
Thanks for the link. I was searching for something like that!
Don (Flboy)
https://youtu.be/6_-8cVdWUIA
https://youtu.be/MUcMM86LA2g
flboy
Images: 378
Postby piperpilot3tk » Mon Mar 29, 2021 7:00 pm
You can use two large clamps to clamp the portaband table to a work bench or welding table to keep it put. Can also clamp it to the tubes of a trailer tongue to help make repairs in the field.
piperpilot3tk
Images: 29
Postby flboy » Mon Mar 29, 2021 7:04 pm
Will do that. I ordered one today. Many thanks for the info.
Sent from my SM-N970U using Tapatalk
Don (Flboy)
flboy
Images: 378
Postby featherliteCT1 » Sat Apr 10, 2021 4:17 pm
flboy,
Have you tested your WZRELB 1500W Pure Sine Inverter with your oscillator to see how clean the output wave is under load? I have been watching youtube reviews of "pure" sine wave inverters and notice that some have dirty output.
featherliteCT1
Postby flboy » Sat Apr 10, 2021 5:36 pm
featherliteCT1 wrote:flboy,
I am assuming you meant oscilloscope... but no. When I install it in the new CTC, I will check it out. I do get Electromagnetic Noise (EMI) from it regardless of load. You notice that on the HF Radio audio and can see it on the panoramic display. . But that is not surprising. I just turn it off when using the HF radio. Just about all of them but the most expensive will create some EMI.
Don (Flboy)
flboy
Images: 378
Postby featherliteCT1 » Sat Apr 10, 2021 6:03 pm
"oscilloscope", yes. :lol:
The specs for that inverter say 1.5A no load draw. Do you think that it actually draws that much no load current?
I am looking to buy another pure sine wave inverter, maybe about 1000 to 1500 watts. My Renogy 700 watt actually draws about .5 amps no load. The specs for the Renogy 1000 watt also say about .5 amps no load draw.
featherliteCT1
Postby flboy » Sat Apr 10, 2021 10:10 pm
featherliteCT1 wrote:"oscilloscope", yes. :lol:
The one I have draws about .5A in standby.
Don (Flboy)
flboy
Images: 378
Postby flboy » Tue Apr 13, 2021 11:46 am
My 280ah LiFePo4 batteries have arrived! 11 weeks it took... but hopefully worth the wait. I already have the 150a Bluetooth BMS, so I will build the bank this week.
Don (Flboy)
flboy
Images: 378
Postby bdosborn » Tue Apr 13, 2021 3:32 pm
Hey! Your stuff is bigger than mine! :lol: Nice choice, those cells are very popular. :thumbsup:
Images: 806
Postby BigDave_185 » Tue Apr 13, 2021 6:26 pm
flboy wrote:My 280ah LiFePo4 batteries have arrived! 11 weeks it took... but hopefully worth the wait. I already have the 150a Bluetooth BMS, so I will build the bank this week.
So what is this system for now?
BigDave_185
Postby flboy » Tue Apr 13, 2021 7:06 pm
This is for my new 6*12 Cargo Trailer conversion. Still waiting for the trailer I ordered.
Don (Flboy)
flboy
Images: 378
Postby flboy » Tue Apr 13, 2021 7:14 pm
So far so good. The cells all appear to be close to fully charged and all read 3.32 vdc exactly. They look to be in perfect shape. I hooked up the lab Power Supply to top balance them, and the are only drawing 3.55A.
Assuming they are done balancing by tomorrow, I will build these up. I ordered a Group 27 Marine battery box to put these in with the BMS. Based on measurements, they should fit. Hard to believe 280aH usable in a Group 27 size.
Don (Flboy)
flboy
Images: 378
Postby bdosborn » Tue Apr 13, 2021 7:19 pm
https://www.gudgeonblog.ca/lifepo4-batteries-part-four-top-balancing-pack/
I had to re-balance one of my batteries because I didn't repeat the charge to 3.65V (I think)...
Images: 806
