dogcatcher wrote:Websites will be your best bet. Search "tiny house on wheels" and "tiny house" Sign up for any news letters etc. Keep a folder for photos of ideas that you like. Pics of floor plans can be free, they can be adjusted to your wants and needs.
Here is a start.
https://tinyhousetalk.com/how-they-foun ... tiny-home/
http://tinyhousenewsletter.com/
woodie72 wrote:
...........Would using thin shiplapped red cedar, laps epoxied and boards epoxied to the foam and ply on the inside create structurally sound panels ?...........
I would recommend against that. The cedar will expand and contract with moisture unless completely encapsulated probably causing the glue joints to fail eventually. Successfully gluing anything to foam means maximizing the gluing surface area.
If you are going to fiberglass, I take a look at thin marine ply. I can get 3mm Meranti or Okume over here and they are both beautiful under fiberglass.
20mm foam might be good enough if your lamination is top notch. We're probably talking vacuum bagging on a really flat work table.
pchast wrote:I believe there is no need to add a batten to the foam. Depending on the
type of glue used, there may still be need to use clamping regardless of
batten or none. Standard wood glue will stick to prepped foam with a
longer curing time.
Actual best approach is more dependent on how you are attaching your
outside skin?
