I have 2" XPS foam and 10 oz canvas.
I plan on using 50/50 titebond II and water.
My test pieces so far haven't been to successful in terms of nice clean seams.
Could somebody point me to some good examples and links which show the proper technique.
Currently I am doing the following:
1) Put glue mix on foam and canvas.
2) press canvas onto foam with a roller. Wet down the outside canvas with water to help get out wrinkles.
3) Pin down the edges.
4) Wait for first canvas to dry. Cut this canvas once dried to the foam to hopefully allow a nice clean edge.
5) Get my second piece of canvas and run a small strip of glue along an edge. Wait for this to dry and cut this canvas to allow a nice clean cut.
6) Repeat steps 1 to 3 and overlap with the first piece of canvas by about 4".
The problem I am experiencing is that the second piece doesnt seem to want to adhere very well to the first peice..creates a bit of a raggedy edge.
I have tried using straight titebond II for the overlap section and that doesnt seem to help either.
Any help or suggestions would be appreciated.
Keep in mind that this is for a canvas on foam NOT canvas on wood.
Thanks again.
