Build started//Sub 600 lbs / 2 months to build / aerodynamic
Re: Sub 600 lbs / 2 months to build / aerodynamic
Postby GPW » Fri Apr 30, 2021 4:52 am
Nasty stuff when burned , just like plywood and fiberglass resin … :o I can’t imagine that being worse than the inside of a new FEMA trailer … :thinking:
We’ll have to burn test some various foams … although we haven’t heard of any problems in all these years … :NC
We do know a commercial RV or factory trailer will Burn quite Quickly … :shock: ( seen two burn up , fast !!! ) :frightened:
Postby YannG » Fri Apr 30, 2021 12:55 pm
There are videos online and it doesn't seem that flammable. I mean I don't think it would catch fire if you drop a burning match as an example. Of course a constant flame would be different but what wouldn't be.
YannG
Postby twisted lines » Fri Apr 30, 2021 2:54 pm
I have welded large floatation chambers with foam inside, that makes it burn / and stinks worse then a the hot wire.
Filled with water or pump out to balance Very large floating devices.
Racking up; And Rapin foam
twisted lines
Postby QueticoBill » Fri Apr 30, 2021 3:46 pm
Most building and fire codes do not permit exposed foam in buildings. No official will inspect your teardrop so you can do as you please.
I'd still be more concerned by no skin on inside and the strength of foam by itself. A modest impact yo outside meets little resistance.
QB
QueticoBill
Images: 22
Postby YannG » Sat May 01, 2021 6:23 pm
QueticoBill wrote:Most building and fire codes do not permit exposed foam in buildings. No official will inspect your teardrop so you can do as you please.
Lol not sure how we got there but I never said that I would leave it on bare foam ( unless we are talking about someone else). I asked if canvassing the interior was helping structurally or it could be covered with something else like wallpaper or vinyl wrap. Just the sound from bare foam is enough to not want to leave it uncovered.
YannG
Postby YannG » Sat May 01, 2021 6:27 pm
Starting the build probably this week. I will try to take some pictures along the way. I am pretty bad for that but will try.
YannG
Postby GPW » Sun May 02, 2021 3:05 am
Yann, we’ve been building things with styrofoam for decades now , mostly model planes , and we’ve never had anything burn …. :thumbsup:
It’s just plastic like so many other things in our lives that burn . Fire safety is always a must wherever you are !!!
Structurally , BOTH sides of the foam covered makes a much stronger construction , although the outer skin is of greater significance in structural strength ( like a sock ) … ;)
Good Luck Yann !!! :thumbsup:
Postby YannG » Sat May 15, 2021 5:17 pm
Started the build today. Took advices from most so far. Slight slope at the front and another one towards the back. Hopefully it will help for the drag etc. Will round edges as well.
Using what is available from the local store. No TBII in sight. So ran some tests with Elmer's Probond Max which is waterproof. Stick well to EPS.
I will try to take pics as I go. Tried to upload a picture but that ain't working for me. Will have to study the How-to's on photo uploading.
YannG
Postby YannG » Sun May 16, 2021 7:26 am
YannG
Re: Build started//Sub 600 lbs / 2 months to build / aerodyn
Postby YannG » Sun May 16, 2021 7:19 pm
Eh second day working on the small foamie. Did cut a few more panels, made openings for windows and doors. Built the door frame and window frames.
I realized that I may have went a bit heavy on the "mix". OSB edges thickened quite a bit.
Pictures below. Walls are not glued to each other. I was just a bit curious to see how it would look.
Tomorrow I will cut 2 pieces for the roof and will glue window frames and door frame to the foam.
YannG
Postby YannG » Sun May 16, 2021 7:55 pm
YannG
Postby YannG » Sun May 16, 2021 7:59 pm
YannG
Postby GPW » Mon May 17, 2021 4:00 am
Looking Good Yann !!! 8)
Postby YannG » Mon May 17, 2021 4:21 pm
GPW wrote:Looking Good Yann !!! 8)
Thanks. Just a start but I appreciate. Do you know what is best to fill imperfections on the foam? I have a can of spray foam and I saw some people using some kind of spackling.
YannG
Postby twisted lines » Mon May 17, 2021 5:36 pm
Gorilla Glue worked well for a lot of mine.
twisted lines
