180 Degree Awning
180 Degree Awning
Postby DWT77 » Tue May 18, 2021 8:07 am
I am looking at getting a 180 Degree Awning
There might be a small problem that needs to be worked out from what I can see.
They use straps that connect to the other side of the vehicle to tighten the awning.
On my teardrop the hatch raises pretty high and my concern is the straps would get in the way of opening/closing the hatch.
Does anyone have a 180 awning and how did you work this out, if it was a problem for you? or if anyone has any suggestions I might incorporate?
Thanks
DWT77
Images: 473
Re: 180 Degree Awning
Postby saltydawg » Tue May 18, 2021 9:18 am
I do see how that can be an issue, maybe two anchor points, on hatch up one hatch down. That does not solve the issue if you open and close the hatch a lot.
But I dont think your paranoid and its a good question.
Scott
Lost in Maryland
saltydawg
Postby Sparksalot » Tue May 18, 2021 9:32 am
I looked at trying a 180. I would have gone with OVS if I had. In the end I chose an ARB 2500, mine even has the light strip.
Sparksalot
Images: 687
Postby DWT77 » Tue May 18, 2021 9:45 am
saltydawg wrote:I do see how that can be an issue, maybe two anchor points, on hatch up one hatch down. That does not solve the issue if you open and close the hatch a lot.
I was thinking maybe doing another attachment point on the drivers side of my roof rack with a pulley and then over to the passenger side? Might work
DWT77
Images: 473
Postby saltydawg » Tue May 18, 2021 11:20 am
I dont think that would work, it needs the angle pull to help stay open, may anchor to the ground or a tree.
Scott
Lost in Maryland
saltydawg
Postby ricky herbold » Tue May 18, 2021 4:09 pm
I agree, I don’t think that will work. What about a telescopic tube mounted to your roof rack that could extend back and attach to the awning to hold it open
ricky herbold
Postby DWT77 » Wed May 19, 2021 8:08 am
[/quote]I agree, I don’t think that will work. What about a telescopic tube mounted to your roof rack that could extend back and attach to the awning to hold it open[/quote]
Telescopic pole could work. I think there could be two ways to go about it.
Vertical so the pole extends above the hatch
Horizontal so the pole extends past the hatch. Might require a longer pole though
DWT77
Images: 473
Postby ricky herbold » Wed May 19, 2021 3:46 pm
Image[/quote]
I like you first option the best. I was thinking to have it on the same side as the awning. You could have a short fixed strap to secure the awning at the back and then tension up the awning with the front strap.
ricky herbold
Postby ricky herbold » Wed May 19, 2021 3:50 pm
ricky herbold
Postby twisted lines » Wed May 19, 2021 5:31 pm
The 420 Poly cotton Ripp stop canvas Material are you failure with it & Like it?
I picked a material for a boat top for practice late last fall; It faded Horribly, but seamed to be water tight!
Could have bought one done for what I paid :lol:
And I will be looking a Rick's rack again soon :thumbsup:
Racking up; And Rapin foam
twisted lines
