CanuckShooters Build~
Postby CanuckShooter » Wed May 26, 2021 9:15 pm
Just recently took our build out on it's trial run, posted a pile of pictures in my Gallery, unfortunately they aren't exactly in order. I am seeing if this picture attachment works for me. We started with the old camper on the trailer, and ended up with a 7x14 foamie camper with PMF.
P1010021 (1).JPG (431.27 KiB) Viewed 1575 times
CanuckShooter
Images: 123
Re: CanuckShooters Build~
Postby CanuckShooter » Wed May 26, 2021 9:22 pm
165530
CanuckShooter
Images: 123
Postby CanuckShooter » Wed May 26, 2021 9:26 pm
165611
CanuckShooter
Images: 123
Postby CanuckShooter » Wed May 26, 2021 9:30 pm
165531
Here is my first pic, the floor is 1 1/2 x 2 on two foot centers, with extra supports where we would be walking, with half inch ply, I started framing the walls using 2x2 and 2x3 and skinning with birch ply, they said it was 1/4 inch but closer to 3/16th
CanuckShooter
Images: 123
Postby CanuckShooter » Wed May 26, 2021 9:33 pm
165532
165534
Using interior framing [5/8 plywood x 2ft] for additional strength.
CanuckShooter
Images: 123
Postby CanuckShooter » Wed May 26, 2021 9:40 pm
165541
I cut a 2x6 on a slope for the top plate so it slopes back to front,
165538
165539
165542
Then we put a steeper slope on the front with a little bull nose, got the rest of the birch sheathing on and added a detail on the back, wasn't sure if it was needed but the old camper had one and it turned out convenient for mounting lights.
165555
We started gluing on the 1 1/2 foam
CanuckShooter
Images: 123
Postby CanuckShooter » Wed May 26, 2021 9:48 pm
165549
You can see how I trussed the roof with 2x3 and 1x3 to sandwich the top of the plywood bracewalls.
165552
165551
The whole camper is sheathed, we will cut the window and other holes out after the glue is all good and dry.
165556
Furring out all the window/vent and other accessories holes we are making. Po,D after when I found out the local lumber yards sold us a mix of 2x2s some were 1 1/2 x 1 1/2 others were 1 3/8 x 1 3/8 which meant I had to palm sand down all the styro around some spots to smooth out the 1/8th of missing wood.
CanuckShooter
Images: 123
Postby CanuckShooter » Wed May 26, 2021 9:55 pm
165558
165550
using lap stryo so gluing all the joints with carpenters glue
165571
165583
165582
165573
using the lap on the bullnose to create the 'drip edge' I read about while studying everyone else's builds
165584
being creative to avoid making holes in the roof styro
CanuckShooter
Images: 123
Postby CanuckShooter » Wed May 26, 2021 10:00 pm
165589
165591
165592
Canvas being glued on, we use a PVA glue and 2 gal of TB111 as that's what was available here, we tested it first and it worked far better than I was expecting
165587
165593
CanuckShooter
Images: 123
Postby CanuckShooter » Wed May 26, 2021 10:05 pm
165599
Canvas is all glued on and painted with a waterproof stain, took 3 coats to really cover up the weave
165598
windows and other openings all getting filled in
165600
165601
The door didn't seem sturdy when I installed it, so took it off and did some investigating, it's now rebuilt and fully insulated...did you know they use cardboard for insulation in those doors?
165603
165602
CanuckShooter
Images: 123
Postby CanuckShooter » Wed May 26, 2021 10:27 pm
165534
I literally used a saws all to cut the whole lower kitchen unit out of the old camper I used for parts and installed it whole, we reframed the upper cabinets and used the old camper doors. The front bedroom and roof were all painted white and the rest was painted with a grey melamine paint.
165543
165570
165568
165566
165569
While paint and glue was drying we worked on interior details, like propane lines, led lights, painting, installing table etc..
165576
I had a 3 way fridge I bought years ago when I first started to talk about building my own camper, probably about the same time I found the foamies forum.
165560
The battery storage and all the wiring are all hidden in a storage compartment framed in under the front bed, we use 2 6 volt batteries and have a built in charger. The bed can expand from 38x80 to 54x80 when I need a bigger bed.
CanuckShooter
Images: 123
Postby CanuckShooter » Wed May 26, 2021 10:33 pm
165575
The space under the fridge I decided to build my first set of drawer ever! They aren't perfect but work well, the next time I build drawers they will be much better as I learned a lot from my mistakes. You can see the front bed platform in it's narrow stage in this pic.
165578
165581
I added a slide out shelf to the top drawer for more counter space if needed, turns out it's just a little to high to use as a table top
CanuckShooter
Images: 123
Postby CanuckShooter » Wed May 26, 2021 10:39 pm
165605
used some of the alum roof off the old camper for a rock guard
165604
big day, the camper comes out of the shop on a floor dolly and some round fence posts, slow and easy....
165606
165607
165608
165609
165610
165611
Before we lifted it onto the trailer we added a vent cover over the roof vent and an awning track for hanging a tarp off the side.
CanuckShooter
Images: 123
Postby CanuckShooter » Wed May 26, 2021 10:46 pm
165612
Here she is on her maiden voyage....a successful fishing trip. We had below zero, hail, rain, snow, sun, wind and good fishing enjoying the fruits of our labour. My thanks to all the previous posters that let me study how you did things, I can say it worked out very very good and I wouldn't hesitate to encourage others to build their own foamie with pmf.
165613
165615
165614
165616
165617
A friend of mine makes these Boat Totes...nice for fishing!
165618
165619
Thanks for looking, there are more pics in my gallery if you want to see some more. CS
CanuckShooter
Images: 123
Postby GPW » Thu May 27, 2021 3:43 am
WOW !!! Very Nice !!! :thumbsup: :applause: 8)
