printer wrote:Seeing the squaredrop designs and some of the more curved designs I am wondering about which would have less drag. While the teardrop shape looks wing-like the great slope of the back may not be doing much to aid aerodynamics. From what I recall a slope greater than 8-12 degrees results in separation of the airflow from the surface. With the teardrop spun around it would seem to cut the air better, the question is on the wake generated. With a raised back some have incorporated a lip on the back resulting in the air on top of the surface to curl under and fill in some of the negative pressure area reducing the wake.
Or so the theory goes. Anyone have some wisdom they can give to a confused builder?
But I have noticed some doing the opposite, with the sloped front and the tall back. One saying it works great for boats, it works great for them.
printer wrote:Actually you do not need a lot of computing power to get an answer now.
I thought of putting wings on the back ...
tony.latham wrote:I thought of putting wings on the back ...
For what function?
DrewsBrews wrote:Power boats use the flat back because they intentionally want the flow separation. That is how they get on-plane at higher speeds. However boats that need efficiency at slower speeds, such as sail boats, will have a more smooth transition to the transom where it eventually cuts off. I think the idea is to try and keep the slope within the range to keep flow connected as long as possible until you just run out of trailer (or boat). Ideally it would keep going to a point, but that would lead to an unpractically long length. From what I hear, on teardrop trailers the flow typically separates near the galley hinge once the slope becomes too great.
