LiFePO4 DIY options
Anything electric, AC or DC
Re: LiFePO4 DIY options
Postby lfhoward » Fri Jun 18, 2021 5:24 pm
Does anyone have recommendations for a good but not too expensive multimeter? My old orange and green Extech is giving all sorts of wild readings. I replaced the battery, which usually makes it better, but this time is isn’t helping. It seems like the main switch that sets the settings is malfunctioning, or there’s some kind of internal short. Occasionally it settles down and gives a solid reading. Currently we are still at 3.31 volts, verified by the power supply when I turn the amps all the way down.
lfhoward
Postby bdosborn » Fri Jun 18, 2021 6:12 pm
Make sure to get the 1.21 gigawatt capacitor, they're the best.
Images: 806
Postby bdosborn » Fri Jun 18, 2021 6:17 pm
lfhoward wrote:Does anyone have recommendations for a good but not too expensive multimeter?
Fluke. Pay once, cry once.
Images: 806
Postby Tom&Shelly » Fri Jun 18, 2021 6:54 pm
bdosborn wrote:Make sure to get the 1.21 gigawatt capacitor, they're the best.
I remember in our undergrad EE classes (early 80's) joking about the 1 farad capacitors we needed to build our filter designs. (Because we normalized our units. Of course we used scientific notation and could take care of the 10^-6 's later.)
I suppose they don't teach scientific notation to engineers anymore, so the youngsters had to actually go and invent a 1 farad capacitor.
174145 170466 173366
Tom&Shelly
Palladium Donating Member
Images: 2282
Postby lfhoward » Sat Jun 19, 2021 8:41 am
^^^ ha ha, I had to look up how much a farad is. That’s a big capacitor for sure. Not sure it is bigger than a 1.21 gigawatt Flux Capacitor though! :lol: I’m a biologist not an engineer. :D
The big news of the day is the battery pack is now up to 3.32 volts. This really is going to take forever, because as the battery voltage approaches the goal voltage of 3.45, the current (amps) will decrease and approach zero. The amperage started out at something like 2.4 amps and now we are down to about 1.8 amps. Charging is slowing down. At some point next week I will have to call it close enough and crank it up to go for 3.65 volts.
lfhoward
Postby lfhoward » Sat Jun 19, 2021 8:43 am
Seems like everything I need for this project is about $200. :cry:
lfhoward
Postby lfhoward » Sat Jun 19, 2021 11:11 am
I figured out how to mount the BMS to the battery case.
I made a backing plate for it from some aluminum sheet I had left over from the trailer skin.
The BMS has tiny machine screws that were long enough to go through the backing plate, once I countersunk the holes. Then the plate can be screwed directly to the wooden case.
The blue wires will go to battery negative. The black wires will go to the Victron shunt and to the negative bus of the electrical system. I need to make a battery cable to connect the battery positive to the battery shutoff and the positive bus of the electrical system.
lfhoward
Postby tony.latham » Sat Jun 19, 2021 1:15 pm
What kind of biologizer? :thinking:
Postby lfhoward » Sat Jun 19, 2021 1:19 pm
Forest Ecologist
lfhoward
Postby tony.latham » Sat Jun 19, 2021 1:37 pm
Forest Ecologist
Gotcha. I used to chase ecology violators. I caught one once. Supposedly.
Postby lfhoward » Sat Jun 19, 2021 2:45 pm
Re: the slow rate of charge
The battery was getting about 1.5 amps while set to 3.45 volts constant voltage on the power supply. So I turned the setting up to 3.50 volts and the current increased to 2.5 amps. It doesn’t seem like a huge increase but it’s actually 67% more current and this could speed the process up significantly. I will keep an eye on things so the batteries don’t overcharge. When they reach 3.45 volts that’s the time to crank it up to 3.65 and watch the voltage very carefully. At that point we will be only an hour or less away from a full charge. But that could still be days away. The battery is at 3.32 volts right now.
lfhoward
Postby tony.latham » Sat Jun 19, 2021 4:28 pm
When they reach 3.45 volts that’s the time to crank it up to 3.65 and watch...
Is all of this just for the first charge? :thinking:
Postby lfhoward » Sat Jun 19, 2021 4:43 pm
Yes. Some of the people I read talked about a shortcut of charging part of the way with the battery arranged in series using a 12 volt lithium battery charger, then going to parallel for the top balance. Most advocate starting in parallel for the whole charge/top balance sequence but knowing it will take a long time. That’s what I did.
lfhoward
Postby tony.latham » Sat Jun 19, 2021 4:45 pm
Yes.
Thanks for the explanation. Me? I'm assembling fishing (and camping) gear. We have to go chase some westslopes.
Postby lfhoward » Sat Jun 19, 2021 4:47 pm
tony.latham wrote:
Yes.
Fishing and camping sound good! Hope it’s a good trip. Are you under that western heat dome?
lfhoward
Return to Electrical Secrets
