Are you under that western heat dome?
We are... it's been a bit brutal. Where we're headed should be a bit cooler.
lfhoward wrote:^^^ ha ha, I had to look up how much a farad is. That’s a big capacitor for sure. Not sure it is bigger than a 1.21 gigawatt Flux Capacitor though! I’m a biologist not an engineer.
I once worked on an industry team where we built a system to correct the effects of atmospheric turbulence on laser communications systems.
I will plan to sit with the battery and babysit it ...
tony.latham wrote:I once worked on an industry team where we built a system to correct the effects of atmospheric turbulence on laser communications systems.
That's about six feet above my pay grade. Probably more.
