Build started//Sub 600 lbs / 2 months to build / aerodynamic
Re: Build started//Sub 600 lbs / 2 months to build / aerodyn
Postby YannG » Tue Jun 22, 2021 5:11 pm
Here are the latest pics. Almost done. Still have to lay the cushion flooring and to find some hardware to secure the foamie to the trailer. I have D-rings on the trailer and on the foamie in all 4 corners. I also installed small brackets on the right side to hook the foam countertop to the outside. No galley but at least I will have a prep surface if needed. I will camp in it a few times before I add shelves and accessories since I am not sure where to install and what I really need.
YannG
Postby YannG » Tue Jun 22, 2021 5:12 pm
YannG
Postby YannG » Tue Jun 22, 2021 5:13 pm
YannG
Postby YannG » Tue Jun 22, 2021 5:14 pm
YannG
Postby YannG » Tue Jun 22, 2021 5:43 pm
Just a note and maybe someone can add to this. When the door and windows are closed, it feels kinda weird inside. Almost like it is negative pressure. Sound travels weird as well. I noticed that some of you have small vents on the side. Would a few vents help with this?
YannG
Postby YannG » Tue Jun 22, 2021 6:09 pm
It is very air tight. Just thinking about breathing the same air all night. Good way to sleep forever ....
YannG
Postby pchast » Tue Jun 22, 2021 8:08 pm
pchast
Images: 97
Postby friz » Tue Jun 22, 2021 8:16 pm
An old adage about building things. "When you are 90% done, you have 50% left to do."
Sent from my SM-G965U using Tapatalk
The "Sin Bin"
150133
friz
Images: 6
Postby YannG » Tue Jun 22, 2021 10:14 pm
Yes something similar to this may work. I would feel less concerned if there are some vents to allow some air to get in and out if I have to keep the windows shut.
YannG
Postby YannG » Tue Jun 22, 2021 10:17 pm
friz wrote:An old adage about building things. "When you are 90% done, you have 50% left to do."
I looked at your build ( I assume it is). Those are some very impressive building skills.
YannG
Postby friz » Wed Jun 23, 2021 7:45 pm
Not all my skills. I bought a CNC kit to reduce the amount of time I spent building. I have a few builds under of various types my belt. I appreciate anything that saves my time.
The "Sin Bin"
150133
friz
Images: 6
Postby YannG » Sun Jun 27, 2021 4:49 pm
Quick question. I did "soak" the 4x8 OSB in the mix. Should I still paint the side that will be facing the road?
YannG
Postby GPW » Mon Jun 28, 2021 3:51 am
YES !!! :thumbsup:
Postby YannG » Mon Jun 28, 2021 9:27 am
GPW wrote:YES !!! :thumbsup:
Thanks. Will do this today then.
YannG
Postby YannG » Mon Jun 28, 2021 11:33 am
I drove the camper to a scale today. Goal was to be under 600 lbs. It is 485 lbs. Woot woot. It is a bit light on the tongue so will now work on a tongue box so I can carry a few accessories on the front instead of the rear. But it is positive as I had no idea how much it would weigh.
YannG
