Cutting canvas for neat seams …
Postby GPW » Fri Jul 23, 2021 4:01 am
One way of cutting neat seams in canvas is to mark the seam to be cut , then apply a THINNED mixture of glue and water to the cut line area . Let it dry . Then cut and it will come out sharp edged and not raggedy … 8) I can’t quite recall where this came from , but I believe George first suggested this , and it works !!!  Seams are inevitable on a Foamie , Neat cuts make it look good … ;) :thumbsup:
Another tip , we found a plastic Bondo spreader from the auto parts store , or something similar, perfect for smoothing out the bubbles during covering … Try it , it works great … :thumbsup:
Re: Cutting canvas for neat seams …
Postby John61CT » Fri Jul 23, 2021 4:22 am
Do you mean trimming before or after gluing to the foam?
John61CT
Postby ghcoe » Fri Jul 23, 2021 6:46 pm
GPW wrote:One way of cutting neat seams in canvas is to mark the seam to be cut , then apply a THINNED mixture of glue and water to the cut line area . Let it dry . Then cut and it will come out sharp edged and not raggedy … 8) I can’t quite recall where this came from , but I believe George first suggested this , and it works !!!  Seams are inevitable on a Foamie , Neat cuts make it look good … ;) :thumbsup:
Thanks GPW!
I explained the method about halfway down this page viewtopic.php?f=55&t=54099&start=465 . I did it on the roof and along the front bottom edge where I came up too short when canvasing the roof. Still looking good. Should work fine wherever you need to splice two sheets of canvas together.
George.
ghcoe
Postby TimC » Fri Jul 23, 2021 9:23 pm
This is life changing! :applause:
I can't wait to try this on my next build. Thanks for sharing.
Tim
Niagara, WI
TimC
Images: 736
Users browsing this forum: TwilaR and 4 guests
