Meanwhile in the Netherlands,...
Re: Meanwhile in the Netherlands,...
Postby smeerkees » Tue Mar 10, 2020 5:43 pm
So it took some mental adjustment for me to go from metal to wood.
First of all i was not really impressed by the quality of my sawcuts using the circular saw. Even using a guidingslide. Yes 1 side (the underside ) of the sawcut of the plank looks great.
But the upside of the sawcut not that good enough. It is just the nature of a circular saw, and yes i had taped every sawline before sawing.
So i went on using a router for all the parts who are in the line of sight.
You can work very precise with a router but it takes some sweet time doing the math leveling the router guides. U can make a mistake easily.
And considdering that some planks needed up to 9 differend cuts so far, you didn't want to make to much mistakes.
Keep in mind that i want to build this part of the teardrop somewhat like a kind of Lego system. And also that the complete floor must be removable.
By that i mean that i want to have the possibility to demount all the loose parts easily when nessesary by just some screws or bolts.
It takes some creativity at times to design al kinds and placing of mountingbrackets.
But after all i am pretty pleased by the result so far.
IMG_2055 verkleind voor tnttt.JPG (33.39 KiB) Viewed 2792 times
IMG_2074 verkleind voor tnttt.JPG (39.68 KiB) Viewed 2792 times
smeerkees
Postby smeerkees » Tue Mar 10, 2020 6:05 pm
I want to route some slots into the top of the horizontal planks to hold the inner walls, and than make some lids with piano hinges for some holdingspace.
On the last foto u can see that i can mount the outerwall directly on the frameribs.
Meanwhile i am sawing al kinds of mounting brackets. Some have to be pretty precise using a mitersaw, and others just with an angle grinder.
I will tig weld them on the existing ribs.
So you know what i am busy with, coming time.
Greetz, SmeerKees.
IMG_2082 verkleind voor tnttt.JPG (49.27 KiB) Viewed 2791 times
IMG_2075 verkleind voor tnttt.JPG (52.62 KiB) Viewed 2791 times
smeerkees
Postby KCStudly » Tue Jun 16, 2020 4:48 pm
I've not been very active on the forum lately, but I have to say the quality of your work... craftsmanship, really... shines though in your pictures. (Thumbs up).
Not sure why you feel the need to take it apart later when you clearly have the skill to make a well fit and water tight camper, but then again, we all get to pick our own design challenges, and that is, in fact, the fun part.
Despite some very minor translation... let's call them variations... your posts are well articulated and enjoyable to follow, so I will be! Cheers and peace to you.
Postby Aguyfromohio » Wed Jun 17, 2020 6:30 am
Like KCStudly said, this is an amazing build. Nice work :applause:
Aguyfromohio
Images: 76
Postby smeerkees » Thu Aug 05, 2021 6:27 am
Hello everybody, here are some updates from the Netherlands.
Wow, i can't believe it has been the amount of time since my last update. I guess you could say it had at least partially to do with the covid bug.
Last summer i geared down bigtime on the work on the teardroptrailer to somewhat minimize human contact because of the bug.
It took some time here in the Netherlands to gain momentum to vaccinate for covid. We started with the olderly people first.
In fact i got my second shot of vaccine just a couple of weeks ago in the second half of July.
That left me with more time at home, so i went ahead for some much needed inside remodelling...
A new kitchen, (the old one was thirty years old) a new floor, smoothed out the walls and fresh paint on the walls and seiling.
Wow, what a difference it all makes!
Now i can spend more time on the teardrop trailer again.
smeerkees
Postby smeerkees » Thu Aug 05, 2021 10:45 am
@ KCStudly,
Because i am working with steel i want to have the opportunity to for instance change my floor with somewhat resonable effort without tearing the complete teardrop trailer down.
The main reason, moisture and water intrusion. Espessially because i built my own doors and hatch.
Building a watertight door and hatch system (in steel) takes a lot of effort and is in my opinion one of the most difficult and time consuming details.
Espessially living here in the Netherlands far outside the USA. Here it is way more difficult to find usable parts for a DIY built.
For instance i still haven't found the type of Hurricane hinge i want over here in Europe. And try a 5 ft. hurricane hinge to sent from the USA without damage.
Smaller parts are easier to post.
Hopefully More about this in a future post.
Greetz, Kees.
smeerkees
Postby smeerkees » Thu Aug 05, 2021 11:20 am
So and now for the fun stuff, PICTURES!!!!
Last winter i have been busy with some woodwork.
Here the basics for the inside deviding walls.
IMG_2109 verkleind voor tnttt.JPG (51.55 KiB) Viewed 1667 times
IMG_2110 verkleind voor tnttt.JPG (44.58 KiB) Viewed 1667 times
smeerkees
Postby smeerkees » Thu Aug 05, 2021 11:26 am
As you can see i have added a 2 mm. thick piece of neopreen on the vertical, and horizontal pieces on the floor. Mainly for eliminating rattle's and squeeks.
The horizontal (counter) plate will be fixed to the steel beams with brackets and screws.
IMG_2124 verkleind voor tnttt.JPG (34.04 KiB) Viewed 1663 times
IMG_2125 verkleind voor tnttt.JPG (38.42 KiB) Viewed 1663 times
smeerkees
Postby smeerkees » Thu Aug 05, 2021 11:45 am
And now for the fun stuff. (miter)sawing the metal for the doors and hatch.
IMG_2112 verkleind voor tnttt.JPG (50.47 KiB) Viewed 1660 times
IMG_2118 verkleind voor tnttt.JPG (55.3 KiB) Viewed 1660 times
IMG_2119 verkleind voor tnttt.JPG (41.9 KiB) Viewed 1660 times
smeerkees
Postby smeerkees » Thu Aug 05, 2021 11:58 am
I had to make a lot of spacers for fitting the doors and hatch. Remember, the doorskin will be wrapped around the sides of the doors, and hatch. And i want to mitersaw each part in a 45 degree angle for welding. The initial tack welds will be done in the actual doorjams using the spacers and clamps.
IMG_2128 verkleind voor tnttt.JPG (46.69 KiB) Viewed 1655 times
IMG_2138 verkleind voor tnttt.JPG (47.68 KiB) Viewed 1655 times
smeerkees
Postby smeerkees » Thu Aug 05, 2021 12:22 pm
As you can see the vertical beams of the hatch must be cut very precise especially because the back form of the teardroptrailer is not round but partially elyptoid.
when you cut more than about 2 mm. in the wrong place the form of the hatch will not be on the same place of the silhouette of the teardroptrailer.
This plus the space for the wrap around skin, plus the mitersaw angles of the squares of the hatch....
But first i need the hinge to use for the hatch. Because it can influence the hight of the hatch.
After that the water seal system.
Now u understand why i think this part of the build is the most difficult, and time consuming. Especially while building with steel.
Oh ja and when welding the curved pieces, try to use as less heat as possible. the bended pieces of steel want to lose their form caused by heat.
When you think about it there is a lot of inner tension (stress) in the bended steel pieces.
smeerkees
Postby smeerkees » Thu Aug 05, 2021 12:33 pm
AND NOW FOR US NERDS!
The hatch gap spaced with just the frame. Is about 8.5 mm
IMG_2131 verkleind voor tnttt.JPG (43.27 KiB) Viewed 1656 times
IMG_2148 verkleind voor tnttt.JPG (32 KiB) Viewed 1656 times
smeerkees
Postby smeerkees » Thu Aug 05, 2021 12:45 pm
And this would be the theoretical endgap of the hatch with the doorskin wraparound. This would be around 5 mm.
I measured the door and hatch gap(s) of my car (a fiat 500 eurospecs) the doorgaps were about 3 mm on the front and back.
The hatchgaps were about 4 mm on the sides and underside.
(Have you ever thought about the size of your cardoorgaps?).......me neither. :o
IMG_2153 verkleind voor tnttt.JPG (39.86 KiB) Viewed 1655 times
IMG_2149 verkleind voor tnttt.JPG (27.47 KiB) Viewed 1655 times
smeerkees
Postby smeerkees » Thu Aug 05, 2021 12:55 pm
Next time i would like to talk something about the availability of our teardroptrailer parts here in the Netherlands (or europe) as compared to the USA.
Greetz for now,
SmeerKees.
smeerkees
Postby smeerkees » Wed Mar 09, 2022 8:19 am
Whow, time flies.
The last time i uploaded some foto's was already august last year.
Well i have been going on since then.
Let me see, welded the doorframes, and the hatchframe, finally found me some decent doorhinges, and made brackets for mounting the doorhinges.
OK, some pictures first.
As you can see spacing out things is the only way to go.
IMG_2160 verkleind voor tnttt.JPG (55.3 KiB) Viewed 1202 times
IMG_2162 verkleind voor tnttt.JPG (33.65 KiB) Viewed 1202 times
IMG_2170 verkleind voor tnttt.JPG (45.14 KiB) Viewed 1202 times
smeerkees
