Mounting License Plate
Postby GarthB » Mon Aug 16, 2021 4:44 am
I am nearing the end of my build and I've begun wondering how others have mounted their license plate to the body of their teardrop in a way that the screw holes are sealed while still allowing removal and replacement of the plate later on? I am attaching the plate to the hatch, not the steel frame. It seems as though using a sealant like ProFlex in each of the holes would make it difficult to remove/replace the screws cleanly later on. Maybe I'm wrong in thinking this.
Thanks for the help!
GarthB
Images: 212
Re: Mounting License Plate
Postby QueticoBill » Mon Aug 16, 2021 5:16 am
Lots of brackets that can be permanently attached that the plate mounts to. Is this under a taillight or separate plate light?
QB
QueticoBill
Images: 22
Postby Tom&Shelly » Mon Aug 16, 2021 5:58 am
GarthB wrote:I am nearing the end of my build and I've begun wondering how others have mounted their license plate to the body of their teardrop in a way that the screw holes are sealed while still allowing removal and replacement of the plate later on? I am attaching the plate to the hatch, not the steel frame. It seems as though using a sealant like ProFlex in each of the holes would make it difficult to remove/replace the screws cleanly later on. Maybe I'm wrong in thinking this.
Blocking in the hatch, and then wood screws to hold a license plate frame. I used small scraps of butyl tape to keep water from penetrating the wood screw holes.
174145 170466 173366
Tom&Shelly
Palladium Donating Member
Images: 2282
Postby swoody126 » Mon Aug 16, 2021 7:14 am
any time i have need for a pivot point or location where a fastener is likely to be removed n replaced in wood i drill an oversized hole and plug it w/ thickened epoxy
in thicker panels small stainless fasteners(nails) are inserted into the edges of the holes to hold the pox in place
in panels that are thinner the epoxified holes are sheathed w/ 6oz cloth which gets faired and finished
the ultimate hole needed can then be drilled thru the epoxy w/o fear of water intrusion into the inner edges of the panel
just an option
sw
swoody126
Postby western traveler » Mon Aug 16, 2021 7:32 am
How sweet is that!!! :applause:
western traveler
Images: 264
Postby tony.latham » Mon Aug 16, 2021 8:36 am
I like Swoody's suggestion of drilling it out and filling with thickened epoxy.
Mine, of course, are sealed with a small squirt of poly varnish from a syringe and I'm fine with it.
Postby TimC » Mon Aug 16, 2021 8:48 am
License plate on a teardrop? Who needs that? :lol:
JK... WI doesn't require trailers below 3k lbs to be registered. I did anyways but I don't display unless I am going to a foreign state (other than WI or MI).
Little ball of butyl tape does the trick.
Tim
Niagara, WI
TimC
Images: 752
Postby saltydawg » Mon Aug 16, 2021 11:21 am
My license plate is attached to a small access hatch for the plumbing access on the rear sink. I used the led license plate light thingies to have a light on the plate. The only issue is they are not removable due the wiring.
Scott
Lost in Maryland
saltydawg
Postby twisted lines » Mon Aug 16, 2021 2:10 pm
TimC wrote:License plate on a teardrop? Who needs that? :lol:
I will not be using one, but the light is required in all 50, Or 52 :thinking:
Racking up; And Rapin foam
twisted lines
Postby GarthB » Mon Aug 16, 2021 7:21 pm
Thank you everyone for the recommendations. I definitely have a few options to consider. :thinking:
GarthB
Images: 212
Postby GarthB » Tue Aug 24, 2021 9:56 pm
Figured I'd post a follow up in regards to which route I ended up choosing. Not sure if anyone has tried this option before, but I decided to go with hanger screws. They have wood threads on one end and machine screw threads on the other. I screwed four of them into the hatch so that I could use a nylon lock nut or a cap nut, like I have shown, to hold the license plate and bracket down. I like the cap nuts because they should protect the 10-24 threads well over the years.
I predrilled each of the holes and made sure to use a healthy amount of polyurethane sealant in and around each hole.
Thanks again for all of the help and feedback everybody.
GarthB
Images: 212
